10-02-2023, 04:09 AM
wonderer99 wonderer99 is offline
Hi all
So I have spent quite a while recently digitising and trying to improve older videos I have. This particular one has these weird vertical lines that go all through the long video and I have no idea what they are or how I can remove them if at all?
Im fairly new to all this but not incompetant and have already run the original noisy video through Neat which didnt seem to do much with the issue of the lines.
Any advice would be most welcome as to how I can tackle them at all?
Many thanks
10-02-2023, 09:13 AM
aramkolt aramkolt is offline
Personally I am not sure, but I think we'd benefit from knowing what your current video chain is and if you try a different VCR or say a commercially produced tape, do the lines go away?
10-02-2023, 10:53 AM
Hook up the VCR to the TV, If the artifacts are there then it's baked in the tapes.
Weird vertical lines on VHS capture? Specific Capture, Record, Transfer 5 09-03-2018 05:23 AM
Vertical lines on PAL VHS transfer? thestarswitcher Restore, Filter, Improve Quality 6 07-29-2018 07:09 PM
Need help with blue vertical lines max_cady Restore, Filter, Improve Quality 3 05-03-2011 04:24 AM
