12-29-2013, 05:13 AM
Cyclone82 Cyclone82 is offline
I am trying to find the cable that connects the TBC to a PC. The manual says RS232, RS422, GPI and the back of the unit says serial/GPI.
Connector looks like this
Can you get these cables on ebay? Or is ayone not using theirs?
i installed the software just to see if i could check out what it was all about but when i open the programe i get a error message saying 'runtime error 8002 invalid port number'
I assume thats because i have not even got the TBC conected to the PC and am just getting too far ahead of myself here so that's why i need to get this cable and hopefully all will be fine.
02-03-2018, 10:31 PM
It needs to be mentioned that most Big VooDoo TBCs are some of the worst I've ever seen. Almost all of them were not transparent, and added a lot of noise to the video signal.
There often show up on eBay, usually in damaged or "untested" condition.
A cable to plug into PC should not at all be needed, merely BNC>composite or s-video.
This was an unanswered question or unresolved issue found during a site audit. It's hard to have an FAQ when the answers are missing, or final outcomes are unknown. At The Digital FAQ support forum, questions are never intentionally ignored, and may have been missed due to a forum glitch or human error. More details on the audit. (In some cases, threads have been edited/updated with newer information.)
12-01-2024, 08:22 PM
I'm aware this is a 6 years old thread but to the OP, the serial cable is just to control the functions and change settings, Your device should be controllable from the front.
DataVideo, AVT-CTB-TVOne, and Key West TBC User Manuals [DOWNLOADS] kpmedia Video Hardware Repair 0 11-21-2011 05:33 AM
How much RAM is needed for capturing video ? rocko Project Planning, Workflows 1 08-20-2011 10:54 PM
Advice Needed on Archiving VHS/8mm/Hi-8 setec astronomer Capture, Record, Transfer 7 01-04-2011 02:43 PM
JVC DR-M10 recorder help needed restauroman Restore, Filter, Improve Quality 2 03-02-2010 08:40 PM
How to split cable TV and cable internet coax for two rooms ? stoogedog Computers 6 12-05-2006 06:15 AM
