03-03-2025, 12:44 PM
thevideotvdude thevideotvdude is offline
I put together an XP machine so I could finally use my Pinnacle PCI 700 capture interface that i bought new at Circuit City back in the mid-2000's. ----- >Procrastination anyone?
40 - Hi8mm *not DV* Sony cam
S-video out.
Captured at Best settings = DV compression . avi files
27GB files for around 2 hrs of videos.
Then I went down the encoding rabbit hole and ended up here.
After hours and hours and hours I found
Hybrid.exe - x265 - Avisynth - QTGMC - Bob Slow settings looks better than the original and only about 13% of the original file size but the encoding takes FOREVER on my ryzen 5800X3D Rtx 3080 Ti. Appears to be CPU bound.
Then I stumbled across this video: KTGMC and KFM using NVidia CUDA
https://youtu.be/CiNj11Nfi00
After hours with google translate, I installed AVISynth+, NEO, KTGMC & KFM, AviUtl
But after creating a AVS sript and drag/drop into AviUlt, I only have video in the lower 3rd - it's greyscaled, displaying 3 frames side by side, Uspide down, with a bunch of scrambled lines in the top 2 3rds . I'm guessing using the incorrect codec ?
My script is :
SetMemoryMax(2048, type=DEV_TYPE_CUDA)
srcfile="C:\Hi8 encoding tests\1st.avi"
AviSource(srcfile)
ConvertToYV12()
AssumeTFF()
#KShowStatic(KAnalyzeStatic(30,15), last)
OnCPU(2)
KMergeStatic(KTGMC(Preset="Slower"), last, KAnalyzeStatic(last,30,15))
OnCUDA(2)
I've tried DirectShowSource, FFVideoSource,
Added lines like:
LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins+\ffms2.dll")
No luck.
But when i drag / drop the video into AviUtl it will play - just not while using the script.
Any ideas? Or know of another way for me to tap into the speed of the GPU using QTGMC ? I've tried Handbrake but the results were no where close to QTGMC's quality.
Appreciate any insights.
03-03-2025, 01:19 PM
Selur Selur is offline
side note: QTGMC through Vapoursynth should be faster than the Avisynth version,..
The following users thank Selur for this useful post: thevideotvdude (03-03-2025)
03-03-2025, 06:29 PM
Hi Selur Thanks for your suggestion.
I now tried using Vapoursynth and the same results as using Avisynth. CPU at 100% GPU is at 1%.
Are these the correct checked Boxes ?
03-03-2025, 09:02 PM
Enabling gpu decoding doesn't really help if your input is in a format that decoder chips do not support.
You might want to enable OpenCL and with latest dev DFTTest2 to leverage the GPU.
