04-30-2025, 07:35 AM
CaseyStelken's Avatar
CaseyStelken CaseyStelken is offline
I'm encoding an old TV commercial using Hybrid v2023.12.02.1 and using the "SpotLess" filter to clean up a few artifacts. It looks terrific.
But I noticed at the very end of the commercial, just the last few frames are suddenly shifted down and to the right for some reason. This only happens when I have the SpotLess filter turned on, so I'm trying out the "ApplyOnlyTo" filter for the first time.
The video has 908 frames total. I selected all the frames in the video EXCEPT the very last few frames that shift out of place with the SpotLess filter enabled:
But when I do this, the SpotLess filter no longer has any visible effect on any of the video. I'm guessing I'm using the "ApplyOnlyTo" function wrong? Is the "range" field supposed to be timestamps rather than video frames? I tried instead entering "00:00.000-00:29.796" for the range, but Hybrid doesn't seem to like that.
Thanks as always for any suggestions!
04-30-2025, 12:04 PM
Aya_Rei Aya_Rei is online now
Saw a videohelp message where Selur wrote "(note that there is a mistake in the description you need to use [a b] instead of [a-b] to filter just the frames a-b."
So try and remove the hyphen in between 0 and 896.
05-01-2025, 02:17 AM
Selur Selur is offline
Yes, it should be:
[0 896]
I hoped the tool-tip, would make that clear:
Each line in the text file or in the mappings string must have one of the following forms:
'a z'
Replaces frame a in the base clip with frame z from the filtered clip.
'[a b] z'
Replaces all frames in the range [a b] of the base clip with frame z from the filtered clip.
'[a b] [y z]'
Replaces all frames in the range [a b] in the base clip with frames in the range [y z] from the filtered clip. If the input and output ranges do not have equal sizes, frames will be duplicated or dropped evenly from [y z] to match the size of [a b]. If y > z, the order of the output frames is reversed.
see also: https://github.com/Irrational-Encodi...th-RemapFrames
Cu Selur
Anyone else having trouble with links on Doom9? stevevid General Discussion 5 08-20-2018 02:46 PM
JVC SR VS20U VCR having trouble Jpass992 Video Hardware Repair 15 08-09-2013 04:06 PM
Trouble with v1900 AIW, ATI shut itself down? Tom_n_Jonna Capture, Record, Transfer 2 06-21-2007 08:51 PM
Trouble with TBC...HELP! Tom_n_Jonna Restore, Filter, Improve Quality 3 01-21-2006 12:39 AM
Having some trouble... Daniel Capture, Record, Transfer 9 06-06-2005 10:25 AM
