06-17-2020, 11:35 AM
evilt1000 evilt1000 is offline
Should I be cropping overscan area in Virtualdub (using this http://www.digitalfaq.com/forum/vide...erly-crop.html) after I have captured or wait until I'm using Avisynth+. I have been capturing old skateboard videos in Vdub with HuffYUV. I don't do much clean up and usually go straight to AviSynth+ using AVSPmod, QTGMC, resize to 720x540 and convert with x264.
06-17-2020, 11:59 AM
It really depends on the filter chain in Avisynth. But if you know how to properly do it in Avisynth, then do so. It's just really easy to make a mistake, whereas it's somewhat hard to screw up in VirtualDub with that GUI preview. Avisynth is crop off pixels, then add back. But must remember multiples of 2, and the whole cannot be odds (32/2=16 and fine, but 30/2=15, bad).
Using Hybrid, I sometimes skip VirtualDub myself, go from lossless to the H264 with QTGMC.
06-17-2020, 12:05 PM
AvsPmod has a preview function that I use.
How to Properly Crop the Overscan in VirtualDub [GUIDE] kpmedia Edit Video, Audio 32 02-01-2021 10:35 PM
AviSynth+TIVTC vs Virtualdub? ELinder Restore, Filter, Improve Quality 1 02-07-2019 11:27 AM
How to load VirtualDub plugins in Avisynth? lordsmurf Restore, Filter, Improve Quality 0 02-13-2018 06:29 AM
VirtualDub and Avisynth filter help? pinheadlarry Restore, Filter, Improve Quality 46 09-17-2014 10:50 PM
Good VHS filter guides? (VirtualDub + Avisynth) premiumcapture Restore, Filter, Improve Quality 3 02-25-2014 11:24 AM
