01-05-2016, 06:03 PM
Luca T Luca T is offline
Hi guys,
Looking for the Tbc on the web I run into the Datavideo STC-100 that is an Ntsc/pal converter with integrated Tbc (or that is what I understood )!
Is it good used as Tbc?
01-05-2016, 06:52 PM
No.
Both the DataVideo and Cypress (AVToolbox) format converters only work when the signal is being switched.
PAL > NTSC = TBC on
NTSC > PAL = TBC on
PAL > PAL = TBC off
NTSC > NTSC = TBC off
The TBC cannot be controlled. It's only enabled when the formats are being converted, not when the signal is be played straight though.
This was a stupid design choice.
The following users thank lordsmurf for this useful post: Luca T (01-05-2016)
01-05-2016, 07:33 PM
Ah what a pity!
It could be useful separately controlled!
Using Datavideo STC-100 as a TBC kbbbb Restore, Filter, Improve Quality 1 07-04-2015 07:35 AM
Panasonic TBC vs. JVC TBC vc. Datavideo TBC vaccastracca Restore, Filter, Improve Quality 12 08-28-2011 03:00 AM
Best way to test DataVideo TBC-1000? cc4npg Capture, Record, Transfer 3 07-16-2011 01:41 AM
DataVideo TBC-1000 vs TBC-4000 via Email or PM Restore, Filter, Improve Quality 1 03-25-2010 07:24 PM
