04-15-2016, 01:55 PM
three_jeeps three_jeeps is offline
I am assembling some gear for video tape transfer and repair and need some clarification wrt TBC. I have a DataVideo TBC-1000 and my understanding is that it does frame-based correction only (True?)
How do I know if I need to use line-based correction? and what are some good units to consider getting?
Comments much appreciated
J
04-15-2016, 04:52 PM
External line tbc's are found as expensive shop units that require ancillary equipment. And $$$. Usually you get a hlgh-end SVHS VCR with a line tbc built-in. Those aren't cheap, either, and a real trek finding one that hasn't been used to death. The other way to get line tbc activity for $100 or often less is to use an older DVD recorder that can be used as a pass-thru unit. You don't record to a pass-thru -- connect the VCR to the DVDR input, then connect the DVDR output to the rest of the capture chain. You don't record the video, you "play thru" the device. A line tbc has to run in circuit before the signal gets to a frame tbc. Few DVDR's can be used for pass-thru, and most that can will not perform well. The favored models are the Panasonic DMR-ES10 and DMR-ES15.
A common but rather mild example of line "wiggles" produced by typical scanline errors without a line tbc is here: http://forum.videohelp.com/threads/3...=1#post1882662. The "fixed" version shown used a DMR-ES15 for line tbc pass-thru.
More severe examples were posted in several threads here. Below are links to 2 samples of scanline errors. The tape was played with a non-tbc VCR. While the bad demo looks like a severe case, it's not as uncommon as you'd think an often appears as less severe but similar and obvious. This sort of top-border flagging and frame slippage happens often with old tapes. Some tapes will play without this severity, some won't. All VCRs without a line tbc will have scanline errors.
- A1_Sample2_bad.mpg is the original capture encoded to MPEG, with frame size slightly reduced to prevent TV overscan from hiding some of the problems.
http://www.digitalfaq.com/forum/atta...sample2_badmpg
- B1_Sample2_fix.mpg is the tape played with a line tbc pass-thru device.
The "fixed" sample linked is a first-stage test repair with only basic denoising, improved afterwards with a better VCR but here addressing only specific issues. The tape is no longer available.
http://www.digitalfaq.com/forum/atta...sample2_fixmpg
The sample links were last posted in digitalfaq 2 weeks ago.
More: http://forum.videohelp.com/threads/3...hat-do-you-use
04-24-2016, 11:36 PM
1. Frame sync TBC = cleans the signal, not the image/visual; example: TBC-1000. TBC-100/1000 is full-frame, process 1 frame at a time
2. Line TBC = cleans the image, not the signal; example: built into JVC/Panasoinc S-VHS VCRs. JVC cleans 1 line at a time (100s per frame), and Panasonic is full-field ("multi-line", still 100s per frame)
3. Frame sync = found in some DVD recorders, not true TBC, special image cleaning properties; example: Panasonic ES10
You need both.
line = clean image
external frame = clean signal
See also:
- http://www.digitalfaq.com/forum/vide...ing-guide.html
- http://www.digitalfaq.com/forum/vide...time-base.html
Using VGA or DVI for LED-based monitors? VideoTechMan Computers 2 01-13-2016 06:06 PM
For Sale: ATI All In Wonder-based capture systems lordsmurf Marketplace 1 05-30-2015 02:57 PM
Free Windows-based VPS client? jadentyhy Computers 1 01-04-2015 05:44 AM
Need website hosting for UK based eLearning business via Email or PM Web Hosting 11 06-12-2011 09:14 AM
Automatically generated DVD Thumbnail-based Menus? Joekster Author, Make Menus, Slideshows, Burn 1 05-23-2011 10:21 PM
