06-13-2016, 01:47 AM
TheCatacomb TheCatacomb is offline
Hello, I would appreciate if I could get help removing dot crawl. I had a faulty TBC-1000 that was causing dot crawl in my recordings and I didn't find out until I no longer had the tapes.
I read the checkmate documentation and this is my novice try:
MPEG2Source("D:\Stone Age\VTS_02_1.d2v", cpu=0)
Checkmate(thr=10, max=20, tthr2=00) # dotcrawl filter
Deen() # edge noise removal
What do you all think? How can I improve this? Thanks in advance.
Original
After
06-13-2016, 02:39 AM
Honestly, it looks fine to me.
I'd note that my preferred use of Avisynth is to first extract MPEG to Huffyuv in VirtualDub. Then let Avisynth only process AVI. MPEG can muck up the process and make it take longer.
06-13-2016, 02:34 PM
try this (for an ntsc source
main=last
main
spline36resize(480,320) # NTSC
spline64resize(720,480) # NTSC
lsfmod
filtered=last
main
mt_edge(mode="min/max",chroma="copy").mt_expand
mymask=last
mt_merge(main, filtered, mymask)
main=last
main
lsfmod
filtered=last
main
mymask=last
06-13-2016, 04:58 PM
main=last
main
lsfmod
filtered=last
main
mymask=last
Never thought about applying a mask. Cool.
This script removes less dot crawl but preserves more detail. I guess that's a compromise that must be made.
Here's an example of this masking method applied to another scene:
Original2
After2
06-13-2016, 07:04 PM
if you want to remove more dot crawl you can use "prewitt" instead:
mt_edge(mode="prewitt",chroma="copy").mt_expand
otherwise simply:
mergeluma(DeStripe(2,3,16),1)
(but it blurs a lot imo)
for herringbones patterns (which are some kind of dot crawl):
F1Quiver(last, "gn", 336, 10, test=false)# pour enlever les herring bones / dot crawl (traits obliques sur edges), résultat excellent pour ski_sample2.avi !!
06-13-2016, 07:05 PM
otherwise simply:
06-13-2016, 10:35 PM
I tried this but I was getting pixelation blocks in certain scenes.
mergeluma(DeStripe(2,3,16),1) did help remove more dot crawl, but as you said, it blurred the image like my first checkmate script.
Issues with removing video noise? dbvilla Restore, Filter, Improve Quality 4 02-10-2015 10:46 PM
Help restoring dot crawl, dropouts, and grain on VHS videos? zack82 Restore, Filter, Improve Quality 18 04-29-2014 08:35 PM
Removing black bars on TV shows for DVD? Superstar Edit Video, Audio 12 03-12-2014 11:55 PM
Removing broadcast hum from TV recordings? Reading Bug Restore, Filter, Improve Quality 5 08-19-2010 04:04 PM
Merging clips and removing commercials mlaviolette Encode, Convert for discs 5 11-12-2004 05:11 PM
