Go Back    Forum > Digital Video > Video Project Help > Encode, Convert for streaming
01-13-2025, 11:35 AM
ehbowen ehbowen is offline
I'm up against a hard deadline of close of business today to have the video ready for my father's funeral on Wednesday. The video has been edited entirely in VideoStudio and it looks beautiful in preview. However, every time I attempt to reder it (venue specs call for mp4, 1920x1080, 29.97 fps) the output crashes at the 9% point, before any preview video is available.
I believe that there is a codec mismatch, which is difficult to understand as my software and workflow has not changed since I was doing this on a regular basis a few years back. However, Billy Boy may have kneecapped Windows. I'm pasting in the codec information from one of the videos and I can upload sample frames. My father is having his memorial service in the same auditorium in which my sister was married and it is very important to our family to be able to render this video.
General
Complete name                            : L:\ErinsWedding.20190727-BridesEntrance (2).avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
Format settings                          : PcmWaveformat
File size                                : 929 MiB
Duration                                 : 1 min 11 s
Overall bit rate                         : 110 Mb/s
Frame rate                               : 59.940 FPS
Writing library                          : VirtualDub2 build 44282/release
Video
Format                                   : Lagarith
Codec ID                                 : LAGS
Bit rate                                 : 110 Mb/s
Width                                    : 720 pixels
Height                                   : 540 pixels
Display aspect ratio                     : 4:3
Frame rate                               : 59.940 (60000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 4.703
Stream size                              : 928 MiB (100%)
Audio
Format                                   : PCM
Format settings                          : Little / Signed
Codec ID                                 : 1
Bit rate mode                            : Constant
Bit rate                                 : 176.4 kb/s
Channel(s)                               : 1 channel
Sampling rate                            : 11.025 kHz
Bit depth                                : 16 bits
Stream size                              : 1.49 MiB (0%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 17  ms (1.01 video frame)
Interleave, preload duration             : 500  ms
File Type: avi ErinsWedding.20190727-BridesEntrance (2)-sample.avi (21.75 MB, 1 downloads)
File Type: avi ErinsWedding.20190727-BridesEntrance2-sample.avi (7.96 MB, 0 downloads)
01-13-2025, 03:39 PM
I can help with this, but I won't be available until after 6-7pm today.
PM me, if that still works.
01-13-2025, 04:44 PM
Well, I finally got it to render. I'm not sure if it's because I paid for the upgrade to the 2023 version, or because I tried turning off "hardware acceleration." But I finally got it, and hopefully they'll extend the deadline since I missed it. But the service isn't until Wednesday, so...
I ask indulgence for overstepping the policy about short clips, but I made a minimum-quality SD render that I could share here. It looks great in full HD.
https://www.digitalfaq.com/forum/att...1&d=1736808198
codec, crashing, rendering error, videostudio
To deinterlace or not? Size to render? BruceOlsen Encode, Convert for streaming 4 07-03-2022 11:18 AM
Vegas Pro render settings? Denicio Encode, Convert for streaming 0 01-10-2022 02:31 PM
Render Problem - Vegas Pro 13 RABinMS Edit Video, Audio 0 02-01-2015 11:38 AM
Ulead VideoStudio 11 Plus thoughts? JonathanEntertainment Author, Make Menus, Slideshows, Burn 6 07-30-2007 02:42 AM
