11-18-2020, 09:27 AM
halopower halopower is offline
I have a problem with 1/2 inch videotapes on spools. standard for VCR, eg Philips LDL 1001. My tapes are from the 70's. Unfortunately, when you try to play them, they make the whole tape path dirty. Everything is stained with some kind of tar. Even the vision drum is dirty after a few minutes of belt travel. They just become a bit plastic from old age. I mean, you don't feel it under your fingers, but you can see it after a while of playback. everything dirty. The tape can even stop a rotating vision drum. A question to everyone what to do with such tapes so that it is possible to play them completely without having to stop the VCR every few minutes, remove the tape and clean the entire track together with the heads to reinsert the tape for a few minutes. In the current situation I cannot rip the tape ... PS. I heard from an audiophile friend that this effect is called the "contact" effect. So the tape does not crumble, as it is not a joke in the case of reel audio tapes, but it gets sticky. I am asking for help from people who had this problem and somehow solved it. best regards
11-18-2020, 11:05 AM
BW37 BW37 is offline
You might find these interesting reads:
http://www.digitalfaq.com/forum/medi...s-ongoing.html
which leads you to this:
https://www.morressier.com/article/t...e2b641284abb13
BW
11-18-2020, 07:51 PM
Formica Formica is offline
Yep. Sticky shed syndrome rears its ugly head. Bake them according to the proper instructions. Don't play another one until you do.
dirt wideotape, philips ldl 1001
Hi8 Tape stays on reel while ejecting? LJFletcher Capture, Record, Transfer 4 11-09-2019 07:37 PM
Tape reel sensor VXA4997 Panasonic Bullabill Video Hardware Repair 2 06-20-2017 04:52 AM
Takeup reel not working on Panasonic NV-J33 spacevis Video Hardware Repair 3 04-04-2017 08:47 AM
6.35mm reel to reel projector? lowelljones General Discussion 1 12-13-2016 10:22 PM
Does anyone here transfer 8mm reel to DVD? Tcel93 Capture, Record, Transfer 8 07-19-2006 02:23 AM
