Closed Thread
08-31-2015, 11:37 PM
chandanshivebharti chandanshivebharti is offline
Hello,
I want to know, What is Dedicated Hosting and its benefits ??
09-01-2015, 12:05 AM
The main benefit is dedicated resources. You're not sharing anything, as you would be on a VPS or shared hosting plan.
But there are other caveats to consider.
- Do you really need dedicated resources? For most people, the answer is "no". Shared or VPS is fine.
- Are the specs of the dedicated server as good as a VPS or shared hosting? Many cheap servers are worse than a decent VPS or even shared plan.
So they're really no "better" than one another -- just different.
If you're looking for a quality dedicated server host, then LiquidWeb, WebhostingBuzz, Baltic Servers, and EuroVPS are some top suggestions.
Need a good web host? — Read our 2018 Review of the Best Web Hosts
Quite often, problems with web sites are caused by having a rotten web host. Worse yet, many hosts try to blame you (the customer) for the problems! So dump that lousy company. Say goodbye to slow sites, unresponsive support techs, and downtime. Find yourself a new host today. Whether you need shared, reseller, VPS, semi-dedicated, cloud, or dedicated hosting, something on our list should be a good upgrade for you.
09-14-2015, 04:33 AM
Chanders Chanders is offline
Think that it will be reasonable to recommend you to compare Hostsailor and Downtownhost
They offer affordable dedicated servers, so take your time to choose the host that suits your needs and provides constant and uninterrupted services and support.
09-14-2015, 04:40 AM
These are both horrible suggestions.
- Downtownhost has had chronic problems since 2013, and is not at all suggested.
- HostSailor is known for spam/hack/abuse, and ignores complaints. (That means you're hosting in a bad neighborhood, and as such it can affect everything from email delivery to SEO to DDoS-related downtime.) They've also left themselves obvious fake reviews online.
Again, our list of recommended hosts is here:
Closed Thread
Best Linux hosting for a dedicated server? AngelineRos Web Hosting 5 08-16-2015 02:55 AM
Basics when choosing shared, VPS or dedicated hosting? Rai_Yan Web Hosting 3 02-02-2015 03:20 AM
Hostgator dedicated vs. reseller hosting? Should I upgrade? via Email or PM Web Hosting 2 11-02-2013 09:29 PM
Stablehost vs MDDHosting - Which is best for semi-dedicated hosting? joms Web Hosting 5 07-15-2013 02:11 AM
