Quantcast Burning M1V Files with Nero? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Authoring VCD, DVD, Blu-ray
10-15-2004, 10:35 PM
dastott dastott is offline
I'm a newbie so any advice would be greatly appreciated. I have an .avi file that is 105 mins, and I want to put it on a KVCD. In TMPGEnc I used the KVCD-CQ-352x480 template and got a file in m1v format. When putting this into Nero it won't burn as a VCD (I turned off standard compliance). I must have missed some steps. What do I need to do? thanks...
Site Staff / Ad Manager
10-15-2004, 10:43 PM
kwag kwag is offline
Hi dastott,
An .m1v is a video stream. It doesn't contain audio.
You must multiplex your .m1v with a .m2v (audio stream), so you then get a .mpg file.
Then Nero will let you import the file.
Please read some of the guides available at www.kvcd.net on the right side.
-kwag
10-16-2004, 01:24 AM
Thanks. I will read them when I get home. It sounds quite complicated!
10-16-2004, 02:28 AM
muaddib muaddib is offline
I believe kwag is a bit tired , as what he really wanted to say is that .mp2 is the audio stream (not .m2v).
The .m2v is also designated to a video stream, but an mpeg2 stream.
10-16-2004, 09:13 AM
Yes. I'll write it 100 times on a paper:
.mp2, not .m2v
.mp2, not .m2v
.mp2, not .m2v
.mp2, not .m2v
.mp2, not .m2v
.mp2, not .m2v
-kwag
Burning a KVCD using Nero sbansal Authoring VCD, DVD, Blu-ray 7 12-11-2005 06:55 PM
Problem with Burning using Nero adellolly Authoring VCD, DVD, Blu-ray 8 07-09-2004 10:29 AM
Burning with Nero 5.5.1.8 ZTM Authoring VCD, DVD, Blu-ray 5 12-25-2003 09:22 PM
Problem after burning with Nero 5 Greig Authoring VCD, DVD, Blu-ray 1 11-26-2003 09:41 AM
Need Help Burning KDVD Using Nero KVCDs Authoring VCD, DVD, Blu-ray 1 06-22-2002 12:40 PM
All times are GMT -5. The time now is 08:29 PM  —  vBulletin © Jelsoft Enterprises Ltd
