Quantcast Headac3he: Downsampling Without Reencoding? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Audio Conversion
09-28-2003, 10:26 AM
Jellygoose Jellygoose is offline
Hi all...
Is there a way to downsample a 48khz .mp2 file into an 44.1khz mp2 file without reencoding and loosing quality?
__________________
j3llyG0053
Site Staff / Ad Manager
09-28-2003, 05:39 PM
jorel jorel is offline
Jell,
without re encode i don't know if is possible.
i think that if you re encode to wave 48k than
again to mp2 44k,you don' t loose anything....
wave is (seems) lossless!
well only the audible difference from 48k to 44k.
48k is better!....i know,some players don't like 48k,
but the sound is better.
Headac3he is the best for me in this case!
09-29-2003, 04:35 AM
Boulder Boulder is offline
It is not possible. Even if you converted to WAV first, the final result will be somewhat worse although you probably won't be able to hear it unless you really try to.
WAV is a lossless format, but if you convert a 160kbps MP2 to WAV, resample to 44.1kHz and then encode to 160kbps MP2, it would be the same as encoding straight from 160kbps 48kHz MP2 to 160kbps 44.1kHz MP2.
Logic, that is
09-29-2003, 04:45 AM
yes Boulder,this was my "fear".
maybe little "cosmetics" in the wave before encode back to mp2
with disguises like gentle equalizations can help a little.
.....running out logic!
Jell & Boulder, take a look:
http://www.ne.jp/asahi/fa/efu/fsconv/fsconv_2.html
ssrc seems better!
09-29-2003, 08:08 AM
Yep, SSRC is the one to use. BeSweet uses it via ssrc.dll, I don't know if HeadAC3he does, but probably it's the same one.
09-29-2003, 07:51 PM
vhelp vhelp is offline
I may have asked this before (but forgot)
Does HeadAC3 have command-line switches (for alternate front-end purposes) ??
Thanks guys,
-vhelp
09-29-2003, 11:11 PM
kwag kwag is offline
Nope.
-kwag
09-30-2003, 07:56 AM
Thanks everybody for your answers and links...
__________________
j3llyG0053
another way of shrinking the file without reencoding? rendalunit Video Encoding and Conversion 15 10-09-2004 05:53 PM
HeadAC3he: HeadAC3he only loads or recognizes half of the file? Raynaldo Audio Conversion 4 05-27-2003 09:40 PM
BBMpeg: Audio Sync Problem after Reencoding EvilFactor Video Encoding and Conversion 2 03-27-2003 12:02 AM
DVD2AVI: Audio levels in downsampling miksmith Video Encoding and Conversion 1 03-22-2003 03:02 AM
Reencoding kvcd from multiple cds? rendalunit Video Encoding and Conversion 5 12-27-2002 06:42 PM
All times are GMT -5. The time now is 02:11 AM  —  vBulletin © Jelsoft Enterprises Ltd
