06-11-2019, 07:32 PM
Sergei316 Sergei316 is offline
You can also slipstream the AHCI drivers into the XP ISO and install the OS that way. It is tedious and took me 3 different burns to get it right, but it does work.
I believe there is a program that uses your XP install disk and your specific motherboard AHCI drivers and will create the ISO. You then burn the disc and install.
I wonder if a USB floppy would work?
06-11-2019, 08:12 PM
JohnCaldwell JohnCaldwell is offline
Depends on your bios but it should. On my board it would, but I decided it wasn't worth the extra effort. The system is so lean I can just turn the thing off and unplug the drive.
Matrox G400 Windows XP capture drivers [DOWNLOAD] lordsmurf Capture, Record, Transfer 12 08-14-2019 09:30 PM
What Professional TBC can I use? danFR Restore, Filter, Improve Quality 1 04-05-2017 03:40 PM
Troubles with ATI drivers, crashing ATI MMC! Audio drivers? LFonseca Capture, Record, Transfer 4 05-03-2015 02:41 PM
Best drivers for ATI All In Wonder Radeon, Windows XP install? peter5on Capture, Record, Transfer 14 08-14-2012 01:51 PM
ATI All In Wonder drivers for Windows Vista or Windows 7 ? Mejnour Restore, Filter, Improve Quality 12 02-01-2012 05:27 AM
