Quantcast Burn with ImgBurn in DVDShrink, modified DVD Shrink 3.2 files [DOWNLOAD] - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Copy DVDs, Duplicate, Replicate
03-19-2011, 10:30 PM
If you're using DVD Shrink, then you should really modify it to use ImgBurn.
Read the preface, then download the files below...
Preface / What This Modification Does
Development on the freeware tool DVD Shrink ended years ago, but it's still a very valuable tool for anybody that wants to quickly re-author a DVD, or even to transcode (aka "shrink") a dual-layer disc to fit a 4.3GB ("4.7GB") single layer DVD-R or DVD+R. Old ≠ useless.
DVD Shrink has three basic functions:
1. Read a disc, which it does terribly and slowly. This method is also somewhat abusive to DVD drives. So use something better, whether it's
  • DVD Decrypter ($0 freeware), which works probably 90% of the time on retail DVDs, but 100% of the time on homemade DVDs.
  • DVDFab ($50) or DVDFab HD Decrypter ($0 but limited), for those few times when DVD Decrypter fails, or
  • Slysoft AnyDVD (~$50). Use DVD Decrypter with AnyDVD running in the background.
  • While a simple drag-and-drop off a disc may work, actual ripping programs tend to be more reliable. Ripper programs will retry the read to bad sectors, while a simple OS copy will barf and halt, failing to copy the DVD contents to your hard drive.
2. Transcode a DVD-Video. This is what DVD Shrink is known for, and what the generic term "DVD shrink" comes from. This is easily one of the best MPEG-2 transcoders available to consumers (and even some professionals), due to its quality controls -- the Adaptive Error Compensation (AEC) and Deep Analysis settings. For example, with AEC set to 'Smooth' and deep analysis turned on, the transcode/"shrunk" disc can appear indistinguishable from the source, at least very close. (This also assumes the source was not overly compressed quality).
3. Burn a disc. This is a function that DVD Shrink only has by use of APIs to other already-installed programs. The original unmodified version of DVD Shrink would connect to the Nero API, and you could then burn with Nero Burning ROM. Because Nero has known issues properly burned DVD-Video format discs (improper 32k gapping of IFO and BUP files, which can lead to playback errors), it was never suggested.
And that's what this post is for....
Add ImgBurn to DVD Shrink
One of the best DVD burning programs that currently exists is ImgBurn, made by the developer of DVD Decrypter (known online as LightningUK!) after that project ended. Best of all, it's freeware. Yes, a free program is outperforming commercially developed applications that routinely sell for $50-100 or more.
To add ImgBurn burning to DVD Shrink, download the files below, and then follow these three easy steps:
  1. Install ImgBurn from the setup file.
  2. Install DVD Shrink from the setup file.
  3. Go to the DVD Shrink folder where the program was installed, and replace the DVD Shrink 3.2.exe with the one in the attached mod file.
    • On Windows XP or 32-bit Windows versions, look in C:\Program Files\DVD Shrink
    • On Windows Vista 64 or Windows 7 64-bit, look in C:\Program Files (x86)\DVD Shrink
And then you're done.
Your DVD copying workflow will be modified as such:
  1. Read a disc in another program (i.e. DVD Decrypter)
  2. Open the ISO or files from your hard drive, and transcode and/or re-author in DVD Shrink
  3. Burn using ImgBurn, as instructed from within DVD Shrink
Disclaimer
Transcoding is an optional part of a duplication process, which is not the same as illegal copying of DVDs.
While I realize this information can be used in illicit behavior (i.e, the ability to rent-and-copy, or to copy DVDs you don't own), I specifically do NOT encourage, condone or in any way approve of this action. Those of us in the hobby community understand that damage that is done when, for example, TV boxes sets are copied and not purchased, which leads to future releases being canceled or passed over by studios. Long-term, copying DVDs for personal gain does nobody any favors. If you use this information to "backup" Netflix or the local rental store, understand that you're only hurting yourself.
The proper use of DVD Shrink is to re-author a DVD to suit your own needs. Or as a way to backup your own collection, when the original disc is either rare (hard/impossible to replace) or factory damaged (skips, won't play properly, etc). DVD Shrink allows you to copy a dual-layer DVD to low-cost DVD-R or DVD+R media. And in this context, the "original" source DVD may very well be something homemade, or even something commercial for which you have the right to edit or copy.
That all needed to be mentioned.
Download Files
To get access to download the files, simply join the forum as a Free Member (it's free!) and that's it. You'll be able to download. We don't send spam or sell your e-mail addresses.
If you're not sure what to do with these ZIP or RAR files, then read this help post.
Or if you have any trouble installing DVD Shrink or ImgBurn, feel free to join the forum as a Free Member and then ask in a reply to this post. Or better yet, after signing up, upgrade to a Premium Member, for the best in one-on-one support for your entire video project.
For your convenience, I've attached the current copy of ImgBurn to this post. Fee free to visit the official ImgBurn site for obtaining the latest copy, should you feel it necessary. (There's nothing wrong with the attached version, and I would imagine most future ImgBurn developments will be attuned to Blu-ray media anyway, and not DVD media.)
File Type: rar DVD Shrink 3.2 Mod - Replace .exe file to Add ImgBurn.rar (577.4 KB, 451 downloads)
__________________
- Did my advice help you? Then become a Premium Member or make a donation.
The following users thank lordsmurf for this useful post: j.rolison (01-22-2012)
12-01-2011, 05:52 PM
madbob madbob is offline
Hello all,
was pleased to find mod to get dvdshrink to run imgburn instead of nero . have installed twice - restarted etc etc and dvdshrink still says burn with nero . have followed your instructions ok ( i hope) but no joy so far . i have never actually used dvdshrink to auto burn before and i would like to be able to ... my system is a bog standard xp 32 1gb celeron with mse and mbam pro running . no tweaks or any such like . what am i doing wrong ? thanks for any ideas . cheers madbob
12-02-2011, 06:30 AM
Originally Posted by madbob View Post
Hello all, was pleased to find mod to get dvdshrink to run imgburn instead of nero . have installed twice - restarted etc etc and dvdshrink still says burn with nero . have followed your instructions ok ( i hope) but no joy so far . i have never actually used dvdshrink to auto burn before and i would like to be able to ... my system is a bog standard xp 32 1gb celeron with mse and mbam pro running . no tweaks or any such like . what am i doing wrong ? thanks for any ideas . cheers madbob
You've simply overlooked it.
DVD Shrink works like this:
  1. Open a disc ISO image, or open files off a hard drive
    • Never open a disc directly. It's bad for the drive, and makes DVD Shrink work much slower. Beyond that, discs with copy protection generally cannot be read, so if you're trying to make an emergency copy of a rare disc, you'll have to rip it in something else first (like DVD Decrypter).
  2. Either re-author (keep movie only), or compress the full disc -- this is basically a pick-and-choose type editor.
  3. Under compression settings, deselect unwanted audio/subtitles, or tweak compression settings
  4. Click the big BACKUP button, which has several more tabs of options --
    • For example, max smooth settings with deep analysis, which takes longest but looks best. In the era of quad core computers, calling it "longest" is almost a joke now, as it's at least as fast as realtime, if not quite a bit more. When DVD Shrink was still new and actively developed, it would take many hours.
    • Disc title
    • CPU priority (best to leave alone), and ability to have computer shut itself off when finished
    • Remove regions by setting all of them
  5. Selecting the target device to burn the new copy, whether it's burned directly to a disc, or burned to an ISO image file on the hard drive.
    • This is where you'll find "Create ISO image file: ISO image file and burn with ImgBurn"
Like this:
__________________
If this site has been as helpful as a book or magazine, then Donate a few Dollars or Upgrade your Membership.
12-15-2011, 03:55 AM
fretless6string fretless6string is offline
I'm running windows 7 64bit. I've used DVDShrink for years now on my old XP system w/ Nero, but my new system will not accept my version of nero & I found IMGBurn to be more efficient... So, I would love to get this to work, but it's like the MOD file isn't being reconized as a viable replacement for the DVD Shrink 3.2 exe file. What am I doing wrong?
12-15-2011, 04:14 AM
Site Staff / Owner and Editor
Just to verify, you're replacing the "installed" EXE file with the modified EXE file, correct? (I've seen where people have tried to "install" (run) the modified file, but it's not an installer. It's a replacement file. Delete the old file, replace it with the new modified version.)
After replacement, does DVDShrink run at all?
Also see the image in post #3 above. The ImgBurn setting is hidden in the dropdown box.
__________________
- Thanks for visiting! | Advertise on The Digital FAQ | Upgrade to Premium Member
12-15-2011, 11:47 AM
Correct. I am deleting the DVD Shrink exe & replacing it with the modified exe & the program will not run.
12-15-2011, 07:20 PM
Alright... two more questions, then:
1. Is it in the C:\Program Files\ folder or the C:\Program Files (x86)\ folder? Remember that this is a 32-bit program and needs to be run from the x86 program files location.
2. Have you tried to run it in XP mode? Not the new VirtualPC intergrated feature, but right clicking on the desktop's shortcut, going into Properties, and choosing XP compatibility mode. I'd opt for SP2, not SP3. That is known to help older software sometimes. Report back if that does or does not work. If it does, I'll add it to the instructions in the first post. If not, we'll keep trying.
For example, I right-clicked on my VLC icon, went to Properties:
__________________
12-16-2011, 02:56 AM
Yeah, I've got it in the C:\Program Files (x86)\ folder... after I place the mod file in the C:\Program Files (x86)\DVD Shrink folder & delete the DVD Shrink 3.2 exe file the shortcut no longer works. It says the file name is not valid. Is it possible that I'm removing the wrong file?
12-16-2011, 03:17 AM
Skip the shortcut. Let's work directly from the files in the PF(x86) folder.
The old EXE is a few hundred kilobytes in size. The new EXE is 1.6MB size. Verify the replacement is actually happening.
Also, what are you using to unRAR the file to being with? There's a chance your location archive tool is corrupting the contents of the RAR file. Using WinRAR is suggested -- not something else. You can also try 7zip (freeware), but WinRAR is guaranteed to work. Also consider re-downloading the attached file from the first post, in case your original download was corrupted (unlikely, but possible).
Double-click the EXE to run it. Forget about the shortcut for now. Let's eliminate all possible variables while troubleshooting.
Now see what happens.
Also, did you try the compatibility mode workaround? Be sure to try that, too!
__________________
12-16-2011, 10:13 PM
AHA! I did not unRAR the file... I did so with WinRAR & now it works perfectly. Thanks for all of your help & patience!
VirtualDub for Capturing Video as AVI files [DOWNLOAD] admin Capture, Record, Transfer 0 12-16-2010 03:42 PM
Use Ycopy to skip bad/problem files when copying in Windows [DOWNLOAD] lordsmurf Computers 0 12-03-2010 01:08 PM
Download Google Books (as JPEG/PNG source files for printing to PDF) lordsmurf Computers 0 11-16-2010 06:56 AM
How do i download so i can burn to disc stoogedog Web Streaming Video Help 5 10-11-2006 05:27 AM
Converting iTunes download files? debwalsh Encode, Convert 3 03-15-2006 06:59 AM
All times are GMT -5. The time now is 07:53 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
