Go Back    Forum > Digital Video > Video Project Help > Author, Make Menus, Slideshows, Burn
06-28-2005, 07:38 AM
cptdunsal cptdunsal is offline
Can someone explain to me how I can remove the buttons in the menu option of Nero VisionExpress so its only text. Assuming it can be done at all.
Thanks for the help.
06-28-2005, 10:31 AM
Don't think it can be done.
Nero Vision is newbieware. No options, which is often bad.
I would suggest using other authoring software.
06-28-2005, 10:33 PM
wayshway wayshway is offline
Send a message via AIM to wayshway
It can't be done. I've been using Nero until I get some better software. Just play with it. I'm sure you'll find a button that's workable.
Bobby
Removing split screens from credits lordsmurf Edit Video, Audio 5 07-16-2006 05:08 PM
Nero 6.6 problems MagnificentMarcus Copy DVDs, Duplicate, Replicate 8 03-03-2006 03:32 AM
Verification with Nero 6 MagnificentMarcus Blank Media 10 09-13-2005 05:57 PM
Old Nero Version dminches Author, Make Menus, Slideshows, Burn 1 12-08-2004 12:56 PM
Merging clips and removing commercials mlaviolette Encode, Convert for discs 5 11-12-2004 05:11 PM
