05-20-2009, 07:45 AM
justfax justfax is offline
Article@ http://www.digitalfaq.com/reviews/dvd-media.htm that reviews dvd-r media, doesn't work for me. Using dvd indentifer, excellent codes Verbatim dvd-r MCC03RG20 and TDK dvd-r MCC03RG20 did not do a good job on my stand alone dvd players. There was pixalating and freezing. They were burnt at 2x. Memorex with code RITEKF1 was also very poor. Achieved good results from these two, hp dvd-r CMCMAGAM3 and Maxell dvd-r RITEKF1. So far, the manufactures didn't matter. Perhaps just a coincidence, the 2 brands that worked well had a different color coating HP (red) and Maxell (gold) .
05-20-2009, 04:07 PM
Hi welcome to the site, thanks for the post. Let's see about getting you some help...
The bigger reason for failure here is likely a mix of drive age (and firmware), mixed with the 2x burn speed. There may be some other issues, but let's deal with these first.
Is there a reason that you want or need to burn at only 2x? In all likelihood, that is the root of your problems.
Source problem or bad workflow: DVD quality vs VHS quality Mejnour Project Planning, Workflows 5 12-30-2011 01:15 PM
DVD not playing back and freezing up SALSCO1 Blank Media 1 12-28-2011 06:29 AM
Review on quality of BD-R and BD-RE? Same as DVD media? lordsmurf Blank Media 0 11-04-2011 09:44 AM
Problem with Encoding freezing up Superstar Encode, Convert for discs 1 07-05-2010 11:37 AM
DVD+RW Media Problem On MAC bluelytes Blank Media 2 01-07-2009 01:26 AM
