Go Back    Forum > Digital Life > Tech Myths, Misinformation
08-11-2014, 02:48 PM
I have recently started to question the idea of always using a TBC. In addition to my personal experiences, I cite the following two articles:
http://www.studio1productions.com/Articles/TBC.htm
http://www.htforum.nl/yabbse/index.p...=27890.0;imode
Perhaps I am misunderstanding terminology here, but it seems that a time base corrector corrects distorted and wavy video, including flagging. This would mean that what is commonly referred to as a 'line' time base corrector is in fact just a regular time base corrector.
A frame synchronizer, on the other are what the TBC 1000 and AVT 8710 perform - they regulate the framerate for better capture.
Here's the question here - if a TBC as included in a VCR and a frame synchronizer perform different tasks, and VirtualDub resyncs video and audio on the fly, then technically speaking, shouldn't a TBC in a VCR be necessary, while the external units should not be? Isn't VirtualDub performing the same job that these units are?
Perhaps I am confusing terms here, but it doesn't make sense to me that an external synchronizer should be necessary if the software is synchronizing on its own, and perhaps even doing a better job.
08-11-2014, 03:20 PM
99%+ of the time, it's fact -- TBC is needed for analog video.
Those articles you've linked to have some errors and missing information. For example, that second link is confusing a frame sync with a gen lock -- both of which can be TBC functionality. But they're not the same.
VirtualDub is just software. It cannot do anything.
I'll explain more later. Busy right now.
08-12-2014, 04:23 PM
VirtualDub is forced to deal with the capture hardware you're using, which can generally only adapt to a signal that's mildly outside of the accepted range. The external units are designed to have a wider tolerance for signals that deviate from the expected standards.
Confusion of "Time Base Corrector" vs. "Frame Synchronizer" isn't something that originated with hobbyists; it's all over the pro world. Lordsmurf has always preferred to use terminology based on the apparent effect of a given unit rather than its advertised or technical name; if you go back through the VideoHelp archives there are some informative debates between him and Davideck.
Dana Lee (Ryerson University) - Time Base Correctors and Frame Synchronizers
08-27-2014, 05:12 AM
I want to partially revisit this right now. But later on, I want to expand the TBC sticky even further to better clarify things.
RE: http://www.digitalfaq.com/forum/vide...time-base.html
The video above is excellent for explaining some quick tidbits about the technical side of TBC. Everything mentioned there is accurate. The only problem with this video is that implementation in devices is not always so precise. Hence all the confusion and disagreements about what a TBC is.
As msgohan stated, this happens professionally, nut just among the hobby crowd.
You have several technical items:
- a line TBC
- a multi-line TBC, aka full-field TBC, aka infinite window TBC
- a frame sync
- a frame sync TBC
From there, things quickly get murky.
The sort of buffer attached to the TBC can help define what it does as well.
It's location in the workflow path can help define what it does -- and that includes inside components like cameras, DVD recorders, and VCRs
Many more can be crippled to allow error to pass (anti-copy like Macrovision). Or rather, not "crippled" but not built 100% properly to begin with. Thus, not really a TBC or even a non-TBC frame sync. It's a quasi/pseudo TBC-like device, which has signal leaks. They fail about 50% of the time. These are also cheaper to make, since most have poor buffers, and missing chips/components. Some DVD recorders, most DV boxes, and other items fit here. A true TBC is at least $100 or more to build, so it should be obvious that the prices of those cheap devices do not have one. (Note: The ADVC-300 is expensive because of the poor NR and proc amp, and because you're buying the Canopus name. So no TBC there either.)
Most DVD recorders just have basic frame syncs on input. Few have the more unusual insides.
Various errors interact differently with different types of TBCs or non-TBCs.
That's why explaining things is best done with examples by device type.
For example,
S-VHS VCRs have line TBCs or multi-line TBCs, with decent (but still somewhat small!) 2mb-4mb buffers, and can clean up about 90% of the errors. These have no frame sync, either TBC or non-TBC type, and thus do nothing for this. Capture cards grab video in frames, so when the signal is not frame synced, errors can occur. This fix is to add the external frame sync TBC after the VCR.
So: FACT.
The following users thank lordsmurf for this useful post: Winsordawson (08-28-2014)
08-28-2014, 09:30 PM
So it sounds like a TBC is necessary due to the nature of VHS, with such hardware only being included in VCRs, camcorders, and DVD recorders to a degree. These devices affect how the original picture quality is presented and captured.
I still question the necessity of the frame sync, however. If a tape is sending garbage in, I don't see why software couldn't perform the same task as the TBC-100/0 and AVT perform. These devices don't perform the line corrections necessary for stable playback, and capture rate can be configured through software. If there is no usable picture sent by the VCR, I don't quite understand what the devices above do to correct those errors.
I realize that broadcast houses use these devices on a regular basis, and switching between one source and another can cause timing errors that need to be fixed by frame synchronizers to guarantee continuous, synced broadcast, but when capturing one source, I don't quite see the need. What am I missing?
08-29-2014, 08:42 AM
I can't offer a scientific, by-the-numbers explanation for the following, but it is one example from my own experience.
A nephew gives me a VHS tape of a 3-hour football broadcast recorded off cable on a decent Panasonic VCR. Had a nice sharp image even at 6-hour speed, but the usual EP noise problems, some chroma shift, a little color bleed, and spots all over the place. The problem with the tape was that the nephew and enthusiastic roommates kept using the fast-foward/stop and replay features, physically bruising the tape at many points. I didn't have my AG-1980 or other tbc unit around, so I played this tape on a Panasonic PV-S4670 with s-video out. What I got at many points was a variety of effects including upper border tearing, ripples, dropped frames, frame hopping, dropouts, blue screens, angular stretching, etc., etc.
Hooked this up to a Toshiba RD-XS34 for its line tbc pass-thru. It solved a lot of problems. The tearing was gone and most of the ripples except some of the worst that were due to tape damage, and image distortion and line wiggles were cleared. I've used that pass-thru on copy protected tapes, and it always defeated Macrovision. But this time I still got some dropped frames, a few blue screens, and some frame hops and stutter. Ultimately I got smooth playback after adding the AVT-8710 to the circuit.
So my conclusion from this experience is that the pass-thru solved some in-frame problems, but there were frame-by-frame discrepancies that the unit's frame sync circuit didn't address. The pass-thru got a few frame level problems correct, but not all of them. So I think lordsmurf's description of some of the shortfalls of pass-thru units applies here.
Couple of years later I played this tape on an AG-1980 without the pass-thru unit. I had similar frame-level results and had to add the AVT to get better frame sync. The AVT also fixed the problem of audio momentarily and slightly losing exact sync or giving some occasional wow or sputter in some badly damaged segments. To test this, I used an ES15 for pass-thru instead of the AVT, to compare frame sync problems. It was no contest: the AVT did better work than the pas-thru.
I haven't tried this with decent tapes that haven't been so badly abused. But I did have one tape with Macrovision that kept fooling the pass-thru device so that I had a white 'flash" every now and then, telling me that Macrovision was still doing its dirty work. Had to add the AVT for that tape.
My AVT is the original I purchased in 2004. Still works. Knock wood.
08-30-2014, 04:07 PM
What am I missing?
Well, stop doubting.
What sanlyn has posted is a pretty good example of what happens with a frame sync TBC vs. just using other devices (including non-TBC frame sync). Analog signals are just dirty, and this is what is used to fix them.
08-31-2014, 05:35 PM
Rewording what I said before: what one device considers an unusable signal can be recovered using hardware designed to handle such garbage, up to the second device's own threshold.
This short piece has some diagrams showing synchronization signals that I think most devices would consider to be noise. If a capture device can't recognize a frame exists because it can't decode the timing, it will be dropped no matter your software settings about frame rate.
10-07-2014, 10:25 PM
jazz57 jazz57 is offline
What I find interesting about this is Analog Devices sells chips containing their new ADLLT circuitry described in that paper. The chips, called SDTV decoders, cost only a few dollars. Pairing one of these with a matching encoder should make a TBC to beat all those usually discussed here. I wonder if anyone has tried it.
10-08-2014, 01:06 AM
Analog Devices' offerings are no replacement for the TBCs suggested here, since they are made to respond to Macrovision.
For the chips that include ADLLT (like ADV7280), they describe the feature as "mini TBC functionality." In theory a person could simply buy one of their Evaluation Boards with analog input & output (Product Category: Video Decoders) but the price is more than a few dollars ($152-$1100+).
For the ADV7840 present in my AVR-890, they refer to "Advanced time-base correction (TBC) with frame synchronization" and make no mention of ADLLT or mini-TBC.
10-08-2014, 02:45 AM
From what I was able to to glean from the datasheets "responds to Macrovision" means they detect it but that doesn't necessarily mean you can't use the chip to eliminate it. Just ignore the detection flag in your design. It can also detect a bunch of other stuff like closed-captioning.
By the way I found a unit selling on eBay called the DP-X7001 which does just what we're talking about---a decoder chip followed by an encoder. This one, though, is based on a Phillips SAA7114H from the year 2000. Datasheets says it can handle "weak and distorted" signals. They even give a description on their eBay page.
Too bad those evaluation boards aren't less expensive. I'd hate to try one only to discover poor performance.
10-08-2014, 10:12 AM
The SAA7114H itself is nothing extraordinary. It's used in the AVT-8710 and others. There are capture cards that use it, though its predecessor is the one that was in tons of cards for years. I believe configuration matters a lot, though.
10-08-2014, 01:53 PM
That's too bad. I wish someone would put a modern chip in one of these devices. From the paper you cited it looks like the newer AD devices do an amazing job cleaning up the sync signals--some of those waveforms looked unrecognizable yet the Analog Devices chip was able to generate a usable signal. I'm particularly impressed by how it solved the "top curl" problem, usually referred to as "flagging" here on the forum.
03-20-2017, 03:37 PM
Another YouTube video: Time Base Corrector vs. Frame Synchronizer
12-06-2020, 02:09 AM
- Line TBC is a must for every mechanical video tape playback system when capturing, Most consumer VCR's didn't/don't have it because TV's back in the day had good tolerance to timing errors, not capture cards or devices.
- A full frame TBC don't have frame synchronizer because it converts back to analog, it heavily relies on the frame synchronizer inside the capture software which uses the computer CPU and memory.
- A pro TBC/Synchronizer box have a digital output (usually SDI but firewire had been used as well for lossless in MAC systems), It does the TBC and feed the digital signal to the synchronizer's memory for frame synching within the same PCB, It does not rely on the PC CPU or memory, it streams lossless video to the computer's hard drive via a PCI-SDI card or a USB-SDI adapter.
12-06-2020, 11:19 AM
Those are all facts.
However, with something as complex as TBC, facts can get muddy, especially in practical application.
I know that you like your S&W SDI box, and it's worked well for you, with your sources. That's great, not everybody has that experience with that same hardware. We're all envious. But most pro TBCs (with or without SDI) have issues on consumer sources like VHS or Hi8/Video8. Even something pro like U-matic can choke a unit. Those units were designed with a narrow broadcast application in mind, and deviation quickly runs into issues.
So while the idea of TBC>computer, bypassing a capture card entirely, sounds great -- in practice, not so much.
As I often post, VHS (consumer sources) has a recipe: VCR/camera > TBC > capture card
Not just any unit, but from a menu of specific models.
Straying from the recipe is what usually gets you in trouble.
I truly wish it was easier to capture, and less costly. But it's not. It is what it is.
12-06-2020, 02:36 PM
I'm not trying to be different, I like to experience a lot and learn in the process and share my findings, While some don't feel comfortable with pro gear and others don't feel comfortable with consumer gear it is good to have choices.
While a good gear is no longer made whether pro or consumer. I personally find it more comfortable for me to go the pro route and not have to worry about building an entire Win XP machine just for capturing, Some may find it easier to use an old OS and build upon it. So there is really no "this is better than this" scenario. It's a matter of personal preference.
12-06-2020, 02:43 PM
Yes, I can agree with that. There have been times where I was forced to use different methods, which were inferior in mainstream circumstances. And in those times, I was glad to know what the alternative methodology was. For example, those rare times where you may need to use composite (rather than s-video).
But not really this. There are DEFINITE superior ways to do various things. Some get very nuanced at the top of quality list (example: JVC vs. Panasonic S-VHS VCRs with line TBC), but there is a graded range. And this is especially true with TBCs.
Is this a fake AVT8710 timebase corrector? TylerDurden389 Restore, Filter, Improve Quality 10 06-22-2020 03:02 PM
CDM-630 as a TBC? Composite-only timebase corrector? bhs00 Restore, Filter, Improve Quality 4 02-03-2018 10:27 PM
UK choices for TBC? (timebase corrector) Eagleaye Project Planning, Workflows 10 08-04-2013 02:31 AM
AVT-8710 Multisystem TBC / Frame Synchronizer with Color Corrector, for sale [SOLD] ieee488 Marketplace 10 10-12-2010 12:27 PM
Timebase corrector (TBC) FAQ admin Restore, Filter, Improve Quality 0 02-11-2005 05:29 AM
