07-10-2022, 04:16 PM
AnalogDarling AnalogDarling is offline
Hi, I just set down to capture some videos and I’m getting an odd error I didn’t encounter before. Has anyone had this happen before and how did you solve it?
When I set the Custom Video Format to 720x480 YUY2, it returns the error “The capture device does not support the selected video format” For some reason it is only working when set to 320x240.
Don’t know if this is of any help but the Capture Pin Properties lists resolutions such as 640x240, 720x240. I don’t use capture pin to set the output size but I did notice this.
I’m using the ATI 8500DV and have successfully captured with it when I first set it up.
ATI 8500DV
Virtualdub 1.9.11
YUY2 colorspace
Huffyuv v2.1.1 - CCESP Patch v0.2.2
07-10-2022, 04:58 PM
Did you successfully install the driver?
What Do I Do If I Can't Capture at 720x480 w/ VirtualDub BruceOlsen Capture, Record, Transfer 1 01-03-2020 12:48 AM
Hauppauge USB-Live 2, VirtualDub unable to start capture? Oakleaf Capture, Record, Transfer 6 05-04-2019 10:38 PM
Unable to change output to 720x480 - Osprey card issue? kriscraigs Capture, Record, Transfer 2 01-28-2019 04:26 PM
VirtualDub is unable to see my ATI 600 USB capture card? stevevid Capture, Record, Transfer 8 09-12-2018 01:03 PM
