Go Back    Forum > Digital Photography > Photo Cameras: Buying & Shooting
09-03-2010, 03:12 AM
This is a tiny portion of a conversation that start in email.
Because it may eventually involve a DSLR as an option, I'm adding it into the photo forums...
I will need advice on tripods, camera, lighting, and best practices. Simple things, you could even refer me to a link.
Tripod: Anything sturdy enough to hold the camera. Better tripods have hooks on bottom, where you can adds weights. I use my camera bag of other lenses for my weight.
Camera: Do you want HD (widescreen) or SD? Does it matter? I'd probably opt for HD.
- What sort of budget? I can recommend everything from consumer budget rigs to something that needs its own lenses. In some cases, even a good DSLR may work, but there are limitation.
Lighting: This is one of my weaker areas, as video requires sustained lighting. I'm primarily a still photographer when it comes to shooting. But I can find good information easily, from colleagues who do the shooting.
Microphone: Another area where I'm weak, but actually learning. My new Nikon dSLR camera comes with 720p HD video, and I need a good mic myself. Learning all about condensers, etc.
- Do you plan to use this only inside?
- Does your mic purchase need to work for more "universal" settings?
- Do you want something that can be clipped onto a shirt, held in a hard, or simply mounted on the camera?
Lets get you set up with something.
Best microphone for Nikon D3s, for shooting video lordsmurf Photo Cameras: Buying & Shooting 1 08-31-2010 07:02 PM
Getting MPEG2 artifacts with DVD encoding from AVI/HuffYUV source bbartley9 Encode, Convert for discs 22 08-31-2010 03:55 AM
Lens for shooting concerts? Canon Photo Cameras: Buying & Shooting 3 03-10-2009 08:22 AM
Wireless release, tripod ... anything else? Canon Photo Cameras: Buying & Shooting 1 03-09-2009 11:21 PM
