Go Back    Forum > Digital Photography > Photo Processing, Scanning & Printing
05-04-2013, 01:57 AM
Sossity Sossity is offline
I recently came across some small sketchbooks ranging from 3 x 5 to 8 & 1/2 x 11 that I would like to digitize,
I know I asked something similar in regards to album art, but I would just like a confirmation for scan settings.
I am using my Epson 4490,
is using Epson scan OK to get the initial scan? I usually use it for a few basic settings, & do most of the color tweaking etc in Photoshop.
for settings, I think I may use the same ones as suggested to me for album art, 24 bit, sRGB 600 dpi, I want these for archiving, printing, & the web. will this be good enough for my sketches? the sketches a pencil & colored pencil as well as some inks, & watercolor.
I found some earlier scans of some of my sketches, & they were in Adobe RGB at 24 bit. Should I convert them to sRGB? I dont remember why these settings were used, this may have been before I knew as much about scanning & colors. Now if I use Adobe RGB, I also use 48 bit.
06-13-2013, 03:39 PM
You can if you want. Adobe RGB really isn't used anymore, from what I've seen.
I forget the weaknesses of AdobeRGB, but I'd just never use it. However, I don't go back and always redo everything.
I tend to leave well enough alone, if it's okay, and has no serious flaws.
And I think that's mostly a printing issue anyway. Plus, of I'm not mistaken, you can just open and re-save with a new profile.
07-03-2013, 03:05 AM
Thanks for the response, been away, so I have just now seen this reply. When I can open and resave in another, would it be any good to save an sRGB image to Adobe RGB? I dont think this would gain anything, is it meant if I have an image in Adobe RGB I can save or convert to sRGB.
Scanner suggestion for negative scanning naripeddi Photo Processing, Scanning & Printing 5 01-08-2013 12:56 AM
Scanning paper with sheet fed scanner, JPG vs PDF Sossity Photo Processing, Scanning & Printing 3 11-10-2012 12:06 PM
Converting my albums, ripped in FLAC, to Apple Losseless ? Sossity Digital Devices 1 10-31-2011 09:18 AM
Scanning with ICE vs no ICE [Sample Images] kpmedia Photo Processing, Scanning & Printing 11 03-25-2010 07:33 PM
Looking for program...... scanning comics MOTUfan Project Planning, Workflows 3 01-15-2006 02:29 PM
