09-26-2013, 09:45 PM
metaleonid metaleonid is offline
Just letting you know that there're good deals on both on newegg.com if anyone needs them. Sale ends on September 30th.
USB is $23 after rebate: http://www.newegg.com/Product/Produc...ti%20usb%20750
PCIe is $15 after rebate: http://www.newegg.com/Product/Produc...i%20pcie%20750
I will review USB shortly. It's comparable to ATI USB 600.
The following users thank metaleonid for this useful post: admin (09-26-2013)
09-26-2013, 09:55 PM
WOW! Thanks for the info. I don't think I can resist picking up the PCIe card.
The 750 USB is way worse than the 600 USB in dealing with uncorrected signals, but it should be okay if you use a TBC.
09-26-2013, 11:28 PM
MSGohan, when I first got ATI USB 650, I couldn't use it with VirtualDub version that I had. So I managed to use it with VirtualVcr. It gave me all sorts of crazy AGC problems. Then I got ATI USB 600 and learned that I needed to use VirtualDub 1.9. It worked well. Then I got ATI 550 Pro PCI and ATI 750 USB. 550 gives a bit of white smear. 750 is very similar to 600 and I will review it later.
Now I decided to pull ATI 650 USB out of the box which I was going to sell and test with VirtualDub 1.9. It does not seem to give me AGC problems anymore. What's going on? Is it VirtualVcr vs VirtualDub 1.9?
09-26-2013, 11:52 PM
I'm tempted to get one, but have no idea when I'd get around to testing it. Too much other work to do.
I look forward to your review, however.
09-26-2013, 11:57 PM
Are you testing with the same source as before? Got any uncorrected VHS to play into it?
09-27-2013, 12:20 AM
Right now I am testing with DVD Digital Video Essentials. I don't plan on digitizing VHSs anymore in the near future, but I plan on digitizing LaserDiscs. For LDs I plan on doing parallel simultaneous captures: one via S-Video into ATI USB 600. The other one is via composite into the device that has motion adaptive 3d comb filter. Candidates are ATI USB 650 (need to get 2nd laptop), ATI 750 PCI-e (need to test it and if happy with results, need to buy or borrow a new desktop for this) and the 3rd candidate Panasonic DMR-ES25.
The last one itself will have 2 options. If it digitizes uncompressed into HDMI, I will get Black Magic Intensity Shuttle for Thunderbolt. If not, then I will buy another ATI USB 600.
09-27-2013, 12:46 AM
The ATI 650 cards is a giant POS.
No reason to test that unless you just want a known-bad card in the loop. It has horrible AGC issues. A common goober would notice it! That's bad.
The ES25 is a use I've never seen, based on your posts. That should be interesting to see how it goes.
09-27-2013, 01:01 AM
I was wondering if you tried it with VirtualDub 1.9 and native drivers from VisionTek CD. I just don't understand myself why I do not see AGC problems anymore. I captured 1st 5 minutes of Digital Video Essentials DVD using 600, 650 and 750. I don't notice any AGC issues. The result is pretty much the same as that of ATI 600.
Could it be because I am using drivers from VisionTek CD and use VirtualDub 1.9 as opposed to other drivers and VirtualVCR? Or could it be because I am not using VHS but I am using DVD? Although I do remember that PCI version of it did have AGC issue even with Video Essentials DVD.
09-27-2013, 01:09 AM
Yep. That's probably why.
I use VirtualDub 1.9.x too. As far as drivers go ... don't remember. (I've slept since then. ) Upload them to the forum. Let's see!
The following users thank admin for this useful post: metaleonid (09-27-2013)
09-27-2013, 02:29 AM
Everything we've seen so far shows that DVD sources don't trigger the AGC issues with these devices.
Please contribute to the OriginalTrilogy.com thread I linked in another response. So far the ATI 750 PCIe has been crowned the king of 3D comb filters.
It surely does, but you won't be able to get a pure 480i output. Very few devices seem to allow that. Per the manual your options are 480p/720p/1080i. All of them will bake in the recorder's deinterlacing.
09-27-2013, 08:22 AM
I do remember the same DVD DVE did trigger AGC with the PCI version of this card when I used it with VirtualVCR.
750 PCIe sounds promising. What about AGC issues? Yes/no?
So if I get 480p output, will it be double frame rate? Or will it be stil 29.97 with just deinterlaced frame?
Yep/ That's probably why.
But if for example I will be using Pioneer Elite LD-S2 LaserDisc player with built-in TBC, wouldn't it be pretty similar to DVD player i.e. no AGC?
09-28-2013, 01:32 AM
Can't say one way or the other one regarding AGC.
It will be 480p59.94.
Jagabo triggered AGC issues with his cable box showing a Progressive commercial, so it isn't clear what's necessary to avoid it.
09-28-2013, 02:11 PM
This thread has crossover with this one. http://www.digitalfaq.com/forum/vide...tv-wonder.html
For those that find it via search, or are new to the conversation, read both.
10-06-2013, 07:28 PM
If anyone still wants the 750 USB, they've lowered the sale price so it's now $18 after the $20 MIR.
I was surprised to find that there are a lot of foreign products based on the Theater 750 chip (it's labelled T507 for whatever reason).
U5071
http://www.mygica.com/old/pa/u5071.asp
http://www.geniatech.com/pa/u5071.asp
U5072 (ATSC version)
http://www.mygicausa.com/products/tv-tuners/u5072.html
http://www.geniatech.com/pa/u5072.asp
LV5HD
http://www.notonlytv.net/p_lv5hd.html
X5075
http://www.geniatech.com/pa/X5075.asp
IconBIT Spider Hybrid HD PCI-E 905 FM
http://translate.googleusercontent.c...VVFG-NOsYJhAtw
Compro VideoMate U830F
http://translate.googleusercontent.c...wds2srxtqnhZCg
Compro U2850
http://translate.google.ca/translate...0%26bih%3D1096
10-14-2013, 09:35 AM
Both cards ATI 750 HD PCIe and USB triggered AGC problem with Video Essentials LaserDisc on identical spots. And there's no user way to turn AGC off, right?
10-14-2013, 04:14 PM
What triggers the AGC?
10-14-2013, 05:46 PM
I will post short images in mpeg format later.
07-26-2014, 07:32 AM
Is it later yet?
11-15-2014, 08:25 PM
Sorry.... I have been swamped.
12-17-2014, 11:05 PM
Is it later yet?
Ok, I guess better late than never.
My workflows:
LaserDisc Player Pioneer Elite LD-S2 (second best in the world).
1. BNC composite out to: ATI Wonder HD 750 PCIe.
2. BNC composite out to: Panasonic DMR-ES25 which in turns passes the signal to Component output to the cheap $20 Conexant USB stick with unknown name.
LaserDisc: VideoEssentials.
Look at the frame number 34 in file agc750.avi. It is brighter than the frame 33. This is not the case with agcconexant.avi file which doesn't trigger AGC.
I also attached color bars for both cards captured from LD. Can anyone please help me to adjust proc amp for both cards? Thanks.
ATI All in Wonder 2006 PCIE: TV function does not work kennyb Capture, Record, Transfer 4 05-02-2012 07:02 AM
No TV ATI All in wonder 2006 pcie MMC kennyb Capture, Record, Transfer 0 04-28-2012 11:48 AM
