08-19-2014, 02:31 PM
Reddwarf4ever Reddwarf4ever is offline
Re HD A760gx i am using DVD-RW and DVD+ Disks without problem if I try to use a dual layer disk, I just get the message " open tray to remove disk ".....I am using AONE GOLD PLUS disks.....
I have read that others have issues with dual layer disks...
I researched and found that there are five firmware update files on liteon website. Bit one of them ( zip file ) reports as corrupted, the other four are ok. Not sure if I need to sequentially install each firmware update, or just install the latest ( assume this to be the top one, as they are not dated )
The other issue is, how do I install the firmware update(s) ? The files are not ISO or similar, so can't see how to burn them to a disk.
I am transferring old VHS tapes to DVD, tried the hdmi upscaler and elgato routes, but the quality suffered enormously.....got much better results with the liteon....
Thanks in advance....
08-22-2014, 06:07 AM
DVD recorders have never worked well with dual-layer discs. Not any model, ever.
Firmware updates varied so much, that you really need the instructions for how to updates that exact model.
08-22-2014, 06:51 AM
Yes, but the liteon website gives no indication of how to perform the firmware updates....
08-22-2014, 06:55 AM
I know. You'll have to find archived text somewhere. Sometimes you can use the Archive.org wayback machine, if you can at least track down the URL or where it once was.
I don't have the answer, but I can at least give you some tips.
Lots of firmware required the file be burned a CD to update -- not a DVD.
It's literally been 10+ years since I did LiteOn hacking, so I just don't remember that much anymore. I wish I did.
LiteOn 5005a DVD recorder firmware DDW-813S? punker Video Hardware Repair 2 07-20-2014 09:58 PM
Verbatim Dual layer - am i seeing things? manthing Blank Media 1 06-05-2008 12:24 AM
Dual Layer Discs - Which to get? ninjastriker Blank Media 6 10-04-2006 03:58 AM
Firmware updates MagnificentMarcus Blank Media 1 11-17-2005 08:22 AM
Dual layer and double layer ndbs9u3 Blank Media 2 10-10-2005 03:34 PM
