Closed Thread
12-15-2014, 04:16 PM
zooky zooky is offline
I am in the process of setting up number of sites about 15) ,using shared hosting.I am considering stablehost.Is there any other I should consider?
12-15-2014, 05:05 PM
What are the specs of your sites?
- how many sites
- what is the traffic like (both pageviews and unique visitors per month, NOT hits)
- what powers the sites (WordPress, HTML-only, Joomla, etc)
12-15-2014, 05:19 PM
It will be affiliate money making sites.It will be 15,WordPress, different niche sites.As far as traffic,I do not not have a specific number,but my goal is for each site to generate about $300.00 in revenues.
12-16-2014, 05:06 AM
What's your max budget for this?
Note: Since you're using to make money, the you should match your phone bill budget (~$50), not your Taco Bell lunch budget (under $5). Given that sort of monthly amount, I can help you find something BOTH excellent AND under budget.
What you really need is "reseller" hosting. Understand that it has nothing to do with "reselling" anything (and I hate the term), and it's simply more than multi-account + multi-domain hosting. 1 domain per account is what you want. Trying to cram 15 sites into a single cPanel/Linux account as puny "addon" domains is a performance issue (slow sites!) and a security issue (one site is hacked, all sites are hacked!)
So for reseller, Stablehost is indeed a top choice. I would also look at Veerotech and Site5.
What countries are these sites targeting? That will help narrow it down.
12-16-2014, 11:34 AM
Thanks for clarifying the term,"reseller" hosting.I did not quite understood what it meant previously.My initial intention was to to stuff the 15 sites under a single cPanel, but with that method,as you indicated,there will be performance as well as security issues.What are the typical cost for multi domain hosting? I guess I will have to go with the least reseller cost hosting from the three web hosting choices that you mention.
The countries I will be targeting will be Canada and the USA.
Let me know.
Thanks.
12-16-2014, 05:03 PM
If you're targeting North America, then any host located there will be fine.
You actually have several more options for reseller hosting in USA:
- WebhostingBuzz
- Stream101
- Namecheap
And again, Veerotech, Stablehost and Site5.
For your exact needs, 15 domains, I think WebhostingBuzz will give you the best deal. And they're an excellent host.
12-18-2014, 03:58 PM
Thank you for your choices.I will sign up for WebhostingBuzz.
Closed Thread
Stablehost vs MDD Hosting vs Downtown Host? East coast hosting? faustine Web Hosting 9 08-05-2014 09:46 PM
How to use/manage hosting with multiple domains? (Stablehost?) moonguide Web Hosting 10 11-19-2013 03:29 PM
StableHost, Namecheap or Veerotech for reseller hosting? via Email or PM Web Hosting 6 10-30-2013 09:50 AM
Stablehost, Site5 or Veerotech reseller hosting is best? aimkg Web Hosting 2 10-22-2013 05:25 PM
Stablehost vs MDDHosting - Which is best for semi-dedicated hosting? joms Web Hosting 5 07-15-2013 02:11 AM
