03-01-2021, 10:19 AM
dima dima is offline
I haven't found a different/better place in the forum to post this post - hope this is the right one.
This part marked in the red box(photos are attached to this post) most likely comes from the VCR: JVC HR-S7711, but it is also probably in, for example: JVC HR-S7722 or Philips VR 20D(clone of: JVC HM-DR10000 ?).
What is it for ? What does it do - how does it work ? Is it useful or is it better to remove it ?
If I good know(remember) the tape runs over that white roller, and I guess the whole part of this part can go up and down. Maybe it is part of the equipment of this device working for: "tracking", because it is probably not a Dynamic Drum System as far as I know(it(DDS) is probably from the bottom of the drums) ?
03-01-2021, 11:59 AM
It's a tape tension/tape speed dampener, The inertia of the weight acts as a load which helps put some tension on the tape before it enters the drum so it will have a better head to tape contact. Don't remove it, A lot of people think it's useless but it is not.
The following users thank latreche34 for this useful post: lordsmurf (04-10-2021)
03-02-2021, 05:36 AM
Thank you for your answer and information.
Part number for JVC VCR pinch roller? dima Video Hardware Repair 10 07-03-2020 01:41 AM
JVC HR-S9900U bad ribbon cable, part needed? BelowZero Video Hardware Repair 40 02-06-2020 10:02 PM
Find DVD manufacturer by disc part number? via Email or PM Blank Media 1 07-25-2014 08:06 AM
Bad Burns, Part Deux Neuroslicer Blank Media 7 09-17-2005 07:23 AM
