12-25-2022, 03:57 PM
TOM1 TOM1 is offline
Hello,
I have VCR Panasonic NV-FS200EG (PAL) and I have a problem with the video quality for a few minutes after the first start...
The video is smooth and stable (I think there will be no problem with the video head), but there is a green tint.
The video is fine, but the image is very green (for example blue sky is "green sky").
After some time (a few minutes) and changes (rewinding the cassette, stopping, playing), the green tint disappears and the picture is perfectly fine.
I believe the problem will go away with warming up (but I'm not sure).
Do you think it could be the capacitors causing it?
I am attaching a photo of the source part. There was a lot of dust and grease, so I vacuumed it up for now.
It looks better now, but still some parts are optically bad.
Thank you very much for the suggestion...
12-27-2022, 05:29 AM
cinemaman cinemaman is offline
I am not an expert in this area, but this video might be interesting to you (I believe your vcr is European equivalent of same machine):-
https://www.youtube.com/watch?v=fQ_Ruwmes04
Maybe your vcr capacitor(s) are reacting to temperature changes as they begin to fail.
12-27-2022, 07:01 AM
The AG1980P is very different to the NV-FS200. The older AG1970 is very similar though.
It could be bad capacitors though yeah. The issue clearing itself after being on for a little while is very typical of capacitor issues. I would suspect capacitors on the Y/C or TBC boards rather than the power supply (that's not to say that those couldn't be starting to go bad from use/age too). Not sure which ones in particular though.
fs-200
Panasonic NV-FS200, Panasonic NV-HS1000 or JVC HM-DR10000? puleddu Project Planning, Workflows 15 09-13-2020 04:59 PM
Panasonic AG-7350 or Panasonic NV-FS200 for digitizing tapes? simo1427 Capture, Record, Transfer 3 05-21-2018 04:19 PM
My Panasonic 4661 VCR takes two minutes to FF/Rew? EscapeVelo Video Hardware Repair 1 01-02-2013 01:11 AM
Panasonic FS200 loss of color? rocketsam Video Hardware Repair 2 11-21-2012 06:41 PM
Green in picture even after desaturation / Problem with monitor color? manthing Photo Processing, Scanning & Printing 10 06-19-2011 04:05 PM
