09-05-2018, 04:33 PM
ozstar ozstar is offline
Hi,
I have a HR-S5800AM/HR-S5880AM which has been plugged in on the rack and showing the 4 dashes for maybe 8 years. Yesterday I had to use it for the first time for ages. I put a tape in and it got stuck in there.
After a while it did come out but when it goes in again all the LED lights up for a few secs then it goes back to the 4 dashes. Happens all the time.
The 2025 battery was very low but replaced it but it didn't change anything.
This is the best box I have ever had so don't want to lose it and I am now ready to transfer so many VHS tapes to PC.
I am in Sydney Australia.
I have found this place and am awaiting a quote but would like to know if there are any suggestions.
I've taken the top off, but none of the capacitors I can see are bloated. All looks very clean an good actually. When I put the cassette in the tape does go to the drum, then back, then back to the drum and stops.
http://www.jvpservicecentre.com.au/:
oz
09-14-2018, 07:06 AM
As you already know, similar issues happen with many JVCs: http://www.digitalfaq.com/forum/vcr-...0am-keeps.html
It's a self-protection error, it shuts off.
You must locate the problem.
Finding the problem is generally pretty easy for the dynamic drum units -- of which this is not one.
Without seeing it, hearing it, hard to say. If you can't find a local repairman, perhaps you'll need to shoot some images and video of the internals of the deck, and perhaps somebody here has some ideas.
While I'm good at JVC repair/maintenance -- merely a side effect of having used them for 20+ years now -- others here are better than I at finding some of these issues. At I'm at a loss on this one.
I also see you other post in the 7600AM thread
Many thanks again for the help and advice lordsmurf. I will repost and see if I get any more reactions.
I found a place in Sydney online and awaiting their reply to my request.
oz
The following users thank lordsmurf for this useful post: ozstar (09-14-2018)
hr-s5800am, hr-s5880am, jvc, sydney
JVC HR-S7600AM keeps shutting down after 3 seconds? Blackout Video Hardware Repair 124 12-28-2021 01:55 PM
Tape goes blue every few seconds? octodigitus Capture, Record, Transfer 17 06-17-2021 01:37 AM
Sony SL-F1 Betamax stops playing after 2 seconds? TONYFRANCE Video Hardware Repair 1 06-25-2018 11:38 AM
Jvc dvd recorder drmv150b turns off 30 seconds after trying to startup 3minnesota3 Video Hardware Repair 0 02-06-2016 02:34 PM
Got an AG1980 that ejects tapes seconds after inserting quad4k Video Hardware Repair 15 09-30-2013 01:22 PM
