^+1.
I cannot speak to MAC, however:
I currently use EDIUS 9.5 as my NLE, and I can Export the time line (i.e., Print to Tape) via firewire provided the project matches DV (frame/field rate and size), the hardware presets in the NLE are correct, and of course the PC is able to communicate with the recorder. That has become more involved these days with new PCs not having a IEEE1394 port, and MS abandoning the legacy IEEE1394 protocols with Win8 and newer, and newer software not speaking IEEE1394.
Best to research the forums dedicated to your software and recorder to check compatibility between T-bolt, adapters, and your gear. I have read that there are some issues with backward compatibility as the MAC evolves its own way.
