02-23-2021, 12:44 AM
although windows 10 is not ideal i've read that some have had success with it. this pc came with windows 10 so i figure i give that a try before going the windows xp route.
the ati 600 usb i got off ebay came with the original cd. i installed the windows vista drivers from there.
setup
panasonic dmr-es46v -> composite out -> ati 600 usb -> virtualdub -> avi
sample capture file is attached.
i was following this guide
02-23-2021, 07:59 AM
I'm unable to watch the video, but have you tried using the S-Video output? afaik that one goes through the internal digitizer which should help stabilize the video output. (the dvd-priority out composite output may do as well but not sure.)
02-23-2021, 08:03 AM
unfortunately the dvd/vcr combo only has composite out for vhs. the s-video out is reserved for dvd.
02-23-2021, 08:20 AM
I can't watch your video (using VLC) because you used the Huffyuv Multithreaded codec, which it does not support. Probably best to stick to regular Huffyuv for the broadest player compatibility.
Looks like you're not using a VCR with a TBC or an in-line frame TBC. Jitter is one of the things that TBCs fix. So you may want to pick up a Panasonic ES10/ES15 DVD recorder to pass the VCR's signal through en route to your ATI card. That will likely solve your jitter problem.
02-23-2021, 08:36 AM
Hm, the manual suggests it does at least, just that DVD-playback has priority on those outputs, but it could be wrong I suppose. Did you test it? If not, it's related to the mentioned Panasonic DMR-ES15, so it may work similarly and be able to fulfill a similar role to stabilize video from another vcr by passing it through it.
02-23-2021, 08:54 AM
i tried s-video with the canopus advc 100 when i was going that route and it didn't work. only the composite out worked. i assumed it wouldn't work with the ati 600 usb but i'll give that a try.
read a post from lordsmurf that panasonic players are known to give problems without tbc. read another post from lordsmurf that the es10/15 are a so-so tbcs and might not fix the jitter problems. but the es10/15 route looks much cheaper than getting a true tbc like a datavideo tbc-1000.
i'll switch to regular huffyuv and try to get the s-video working and see if that helps.
02-23-2021, 02:54 PM
Thanks for the replies. I am currently in the process of building a new PC, but that's dependant on me managing to get a graphics card in the current climate. I was planning on running Win10 on it, but perhaps opting for an older version e.g. Win8 might make a difference? Then I could always update later down the road. I've read that Win10 can be tempermental when it comes to video capture, so perhaps this would be my best option?
From what I've seen a TBC is relatively pricey so I'm hesitant to go down that road unless it's necessary. It looks like I could get an ES10 fairly cheap so I'd be more inclined to try that if I can't get things working on my new PC. How exactly would that work - could I just add it to the chain e.g. camcorder > composite > ES10 > S-Video + comp audio > capture card > PC?
Also, on that note, the camcorder supports S-Video, but I don't have an S-Video cable for it. In the first instance would trying S-Video from the camcorder to the capture card make a difference vs using composite video?
02-23-2021, 04:56 PM
this post from lordsmurf gives an overview the ES10 passthrough and this thread has some troubleshooting about the nuts and bolts of how to do the passthrough
02-23-2021, 05:02 PM
Great, I'll look into this, thanks!
02-23-2021, 05:31 PM
Yes you should use S-Video wherever possible. Suitable cables can likely be found cheaply on ebay or amazon or maybe even places like flea markets or thrift stores.
I don't think there is any benefit of Windows 8 over Windows 10 for the purposes of capture. XP is best, followed by Windows 7. Since you're building a PC I assume it will be in a tower case. So it would be pretty trivial/cheap to pick up a second hard drive or SSD and dual boot Win7 (or Win XP if your motherboard supports it) just for capturing purposes.
Maybe your graphics card comment is in regards to wanting a high end one for gaming, which is understandable. But for doing video capture you can use a very basic GPU--there's no need for anything fancy.
TBCs are pricey indeed, and I think we're at the point where the additional quality they give over a Panasonic ES10/ES15 is hardly worth the cost. You can even look for an ES10/ES15 with a busted DVD drive, since you're only using it as a passthru to your capture card.
02-23-2021, 08:58 PM
i can't figure out how to uninstall the huffyuv multithreaded codec. i tried the suggestions in this thread. i deleted the huffyuv file in c:\windows\system32. restarted. did the right-click install of the regular huffyuv but the multithreaded codec is the only one that shows up in virtualdub.
i tried disabling it with mmview but that didn't work either. i tried deleting virtual dub and extracting a fresh copy. that didn't work. it remembered all my settings. i didn't install ffdshow. seems like that adds unnecessary codecs.
i can't play the video in vlc either but i can play it in virtualdub.
s-video works! guess that was just an issue with the canopus advc 100. but it didn't fix my jitter problem. looks like i'll have to get some sort of tbc. s-video capture attached.
i interpreted lordsmurf's post as saying there's a considerable difference. but given the difference in price, i'll be trying the es10/15 passthru first before taking out a second morgage for that tbc.
02-23-2021, 09:44 PM
Correct. Problems, but workarounds. Usually. Maybe.
Why are you using Huffyuv MT? I don't even have that installed anymore. Too many issues, didn't work for capture. (So can't see the sample.) AVI isn't needed here anyway. Compress H.264 or MPEG would suffice for this sort of sample.
Minimum requirement here.
Huh? All VCRs output junk signals, inherent to the format, and need time base correction for capture. Not just Panasonic, but JVC and otherwise. All VCRs. Line TBC just corrects the visuals, frame TBC corrects the signal.
No. ES10/15 fixes visuals, as it has crippled+strong line TBC, and non-TBC frame sync. Sometimes that suffices, sometimes not, about 50/50. You do get the ES10/15 downsides, of posterization, agreesive NR even when "off' (more like hi/lo, not on/off), and standard Panasonic luma mucking (worse for PAL). It's not a TBC, not a TBC replacement. It's sort-of TBC(ish), but lack of frame TBC still ideally needs a weak frame like the DataVideo DVK after it in the workflow.
Wi7 or WinXP.
8 is mostly 10, blah, problems, just not as bad as 10.
Like a teenage girl.
Tips:
- remote is required
- clean unit with alcohol when you get it, you'll be shocked at how nasty consumer items are, and the remote and power cord are always filthiest
- consumer gear was NOT cared for, prepare yourself for POS that may not work "tested" and "working" as described
Essentially.
camera> ES10/15 > capture card
Route audio into ES10/15, there can be lag/delay/sync issues otherwise.
Switching composite<>s-video midstream is often bad, but try it.
Amazon, about $5.
Quality boost, yes.
Not really. s-video cables are often thin, fail, can have noise issues. I throw away several s-video cables annually. Stuff like Monster is junk. The best cables I have were free with my DataVideo TBCs and JVC VCRs when new.
No. ES10/15 is not a TBC, and has quality-hit drawbacks. Sometimes you can suffer through it as preference, sometimes the tape balks at it. The original intention of the ES10/15 was anti-tearing, ie the strong line TBC -- but it's crippled for anti-copy, which mimics natural errors, so fails at both. It was some years later that it became a poor man's TBC, but even then, not really. It wasn't until I found weak frames TBCs, where the ES10/15 acts a pre-processor, that we got to 99% TBC(ish). That works well, flawless, like a TBC, but still with quality hits.
Not always. 000000 errors.
I don't remember how. Too long ago. I'm sure it's documented in the forum.
Correct.
Go for it. Look for improvements, observe negatives. May or may not work, not 99% effective alone as-is.
Not that high ... yet.
I recently saw a "for parts of repair" TBC on eBay for $1k+ tax/shipping.
$1k.
For a broken unit, doesn't work. No returns, as-is.
And it sold.
WTF?
Just FYI, TBC-1000s can be lemons. That even includes the "tested" and "working" units. Half of those people don't even know what the letters "TBC" stand for. I'm not joking.
02-24-2021, 07:24 AM
Hm, I looked at the sample now, it's an very odd error, and it happens in the same way in both samples, even though in the latter one the internal digitizer seems to be stabilizing things otherwise. It's possible it's some software or driver issue as well. Did you try with a different codec?
Converted the samples to 4:2:2 h.264 in case anyone else knows what this sort of error is, it doesn't look like the type of effect you get when the capture card loses sync.
02-24-2021, 07:54 AM
i wasn't able to figure out how to remove the huffyuv multithreaded codec from virtualdub and replace it with the regular one. i think i'd have to figure out how to change the registry entries or something like that.
i'm going to install windows xp and start over with the regular huffyuv codec. hopefully that fixes errors. but it seems picking up a real tbc may be in my future. zoinks!
i discovered that most of the vhs tapes in my collection were played maybe once or twice, if at all and are relatively clean. i hoped because of that i wouldn't need a tbc.
02-24-2021, 08:11 AM
If you have issues with huffyuv, you could also try with lagarith or utvideo instead.
02-26-2021, 02:31 AM
still getting the jittery video with those codecs. thanks for the suggestion though.
it seems hp has removed the legacy boot mode that allows usb/cd installaion of windows xp. only the newer uefi is available.
i started a thread over at r/windowsxp and it looks like i'd have to do considerable work figuring out how to put in a bios that supports legacy boot in order to install the os.
i got this new machine because i figured a new machine would be really good hardware for the vhs captures. but i'm starting to think it might be better to just get a pc with windows xp already on it. the prices on ebay aren't so bad.
03-05-2021, 09:35 PM
my windows xp machine came today and it looks like that has solved the jittery video problem. maybe i don't need a tbc just yet.
i've attached a sample. have a look see and let me know what you think. also take a look at the codecs. virtualdub gave me a lot more options in xp than it did in windows 10. i wasn't sure which to pick exactly but i think i got it right. the sample is very short but i wanted to share the uncompressed video.
sidenote: i've never been so excited to open a box with really old technology in it like i was today.
03-05-2021, 11:33 PM
As hodgey mentioned, the big problem you were seeing wasn't actually jitter. I don't know what the name might be, but the appearance reminds me of screen tearing in the computer graphics sense (unrelated to analog video "tearing/flagging" as usually discussed here).
My memory is fuzzy, but I think I've seen this before with the ATI 600 when connected to certain USB ports. Why would this happen? My complete guess: I figure it's a problem with the transfer speed being briefly interrupted, so a segment of the frame is repeated from earlier and the result is these "hitches".
You can do a lot to improve upon this latest capture. To start, I would set the ATI 600 sharpness control to 0 in its Proc Amp settings. The contrast looks overblown, and there is some line jitter, but fixing those issues may require more/different hardware.
lordsmurf (04-10-2021)
03-06-2021, 02:06 AM
i assumed it was the ati drivers not being designed for windows 10
