03-22-2021, 09:10 AM
Uraz88 Uraz88 is offline
I recently got that dvd recorder dmr-e55 for mistake
i suppose to get a es10 but there was a mistake
should i return it? is worth that machine for transfer a vhs from a super vcr Panasonic nv-fs200?
soon i will get also the jvc dr-m10
03-22-2021, 10:03 AM
It's a model that pre-dates the ES10. I've seen some people report that PAL ones work well, but idk for sure, if you have it you could always test it.
(In case you made a typo, there is also newer model called EH55 that's basically a ES15 with hard drive and should work equally well to the ES15, but I presume you are talking about the actual E55.)
03-22-2021, 10:19 AM
i will try to test it
im waiting the jvc dr-m10 that i heard is good device for encode
03-24-2021, 02:13 AM
E55 is old, previous series.
No.
E55 is not EH55.
03-24-2021, 05:26 AM
From the other thread I see you already have a DMR-EZ48 combo, that one should also be usable for pass-through.
03-24-2021, 05:30 AM
I sold it man
I dont have it anymore
Going to buy a super vhs jvc 7600 or 9600eu
03-24-2021, 04:14 PM
Bogilein Bogilein is offline
No.
E55 is not EH55.
Everything is old when it comes to video capturing - that doesn't count as an argument.
Why should the E55 not work as a passthrough device?
Has anyone ever tested the E55?
I don't think Panasonic has use so many different analog to digital chipsets in their DVD recorder series. I think there were 3-4 different ones. The 1st generation up to the ES10. Then the 2nd generation from the ES15. In between, there was probably another chip (from a third-party manufacturer with LSI or am I wrong).
03-24-2021, 07:29 PM
No it's not.
- legacy = non-new, still used and useful
- old = old, no real need/use, supplanted by better hardware/tech, often replace by now-legacy gear
Because it lacks the passthrough TBC feature of the ES series?
In the 10+ years of production, it was quite a few, almost 1 per year. The biggest issue was they would always screw around with luma, and had "crunchy" encode quality (noise, blocks). So none of their recorders were ever good. The ES10/15 is only good because of the passthrough, and still should not be used for disc creation. PAL seems to have a few 10/15 with-HDD versions, which is surely nice for you.
ES10 and ES15 were really the same series.
The ES20/25 was the 2nd gen, and it was a flop, weak line TBC (did it even actually have a TBC?) that was mostly worthless.
You're not wrong. But the LSI encoder chipset has nothing to do with passthrough. And Panasonic was also dumb about LSI implementation (forced 720 @ low bitrates, etc), and is the only LSI-based recorder to have crappy quality encodes. Even flawed latter LiteOns look better, and that's saying something, because LiteOn owners were quite unhappy and vocal about the green-shaded luma issues.
I'm far more interested in your testing of certain Sony PAL recorders. You've isolated a few good models, and I want to create a sticky/guide here from your information. I always forget where your comparison post is, I'll have to look sometime. I'm more interested in your exposure/value changes findings than the TBC changes.
Certain Toshiba models (NTSC) had similar success at performance, but was also never a TBC, could never entirely replace a TBC. However, good encoding quality!
Panasonic ES10 and ES15 the same for passthrough? colony Capture, Record, Transfer 16 10-03-2022 02:38 PM
Panasonic DMR ES10 passthrough setup? qiko Capture, Record, Transfer 8 04-05-2022 02:06 PM
Is Panasonic DMR-EZ48V passthrough similar to DMR-ES10 / ES15? crunchynutloops Capture, Record, Transfer 3 10-02-2020 08:24 AM
Panasonic ES10 passthrough creates MPEGs? OBNOXIUs Restore, Filter, Improve Quality 4 11-02-2018 11:52 AM
Using Panasonic ES10 DVD as a Passthrough RABinMS Restore, Filter, Improve Quality 7 07-20-2014 06:50 AM
