03-01-2009, 02:14 PM
Kenneth M Kenneth M is offline
Lordy, I know you aren't too much of a fan of the EH55 burner due to the lousy encoders. But, can I use the EH55 for the same benefits as a passthru as you recommed the es10 be used?
03-02-2009, 12:16 AM
No, the EH55 is too old, it's not part of the ES10-and-later series of machines that did filtering.
The ES10 is regarded as the best in that series (ES15, ES20, ES25), but apparently some of the still-on-the-shelf "EZ" series machines can also filter in this manner. I'd look for a DVD-recorder-only "EZ" series machine for cheap (not a combo, no hard drive, etc).
Panasonic DMR-ES18 has sync filters like the ES10 ? sChen77 Restore, Filter, Improve Quality 3 07-01-2012 12:07 AM
Internal TBC VCR or HQ Non-TBC VCR + Panasonic DMR-ES10? LukeS Restore, Filter, Improve Quality 1 10-25-2011 04:06 AM
Wanted Panasonic DMR-ES10 DVD recorder, to use for bypass rodbuilder Marketplace 10 08-30-2011 02:59 PM
Question on the Panasonic DMR-ES10 mrwhitethc Restore, Filter, Improve Quality 4 04-13-2008 07:30 AM
Philips 3575 vs Panasonic DMR-ES10 vs Toshiba XS?? Konfusion Capture, Record, Transfer 4 02-03-2008 08:54 AM
