08-09-2015, 05:27 PM
Goldwingfahrer's Avatar
Remembered
I have an AIWA HR-MX100 that on a master secam recording had horrible horizontal jitter
He is called AIWA MX 100 here.
Unfortunately, no setting for "Edit" or "Tape Dub"
11-24-2017, 05:25 PM
kb5050 kb5050 is offline
Yes it is that composite video is noisier, so then you want to use Svideo anyhow if possible since it will have lnoise but better color which is that it separates color chroma information. But also you're going to typically edit out the black part. With lower quality such as VHS you get even worse results, especially from old VCRs and old tapes. I would not want to go to less than 4 head VCR with HiFi-Stereo but home movies in old camcorders are only analog mono in most cases. Some capture software has noise compensation, but I find that does not do much to clean it up any. A new VCR that is not worn out is probably a better idea. Laser LD discs despite being digital, in older players, are still downconverted to Analog and so the processing results in both sync lines and noise. As technology got better so did the types of outputs, SCART for example is what was used up until totally digital HDMI came along. It is odd that even the most modern TV sets still have RGB SCART rca sockets, to attach your older LD players. Nothing made in the last century does not typically have HDMI which even in 720P is way ahead.
02-07-2021, 02:50 PM
jra166 jra166 is offline
Years ago this thread convinced me to buy the RCA DRC8335. Now that I'm using the Panasonic LQ-MD800P, just wanted to add my Video Essentials test pattern
Pioneer CLD-97 > Panasonic LQ-MD800P (Composite In) > Panny DMR-E55 (S-Video IN for Line-In NR) > Capture Devices
02-07-2021, 04:34 PM
Adding that RCA VCR in the mix made things worse in the original post from years ago, All the details lost, there was barely any chroma left, It might have better comb filter than both the LD and the dazzle but not good enough for archiving.
Diagonal line noise on VHS video? Luma noise? bilditup1 Capture, Record, Transfer 66 10-17-2015 01:03 AM
Video8 playback/capture problems large horizontal bands AJAX1 Capture, Record, Transfer 6 04-04-2015 10:56 PM
Color calibrating your monitor? (Seeing "true" color of your video captures) baywatch242000 Project Planning, Workflows 4 04-09-2014 01:30 PM
Toshiba DX800 won't play, just makes horrible noise DeeSeven Video Hardware Repair 2 02-17-2013 04:40 AM
Very odd VHS tape recording mystery, red/blue color bands on screen jimvhs Capture, Record, Transfer 6 09-17-2011 11:51 PM
