11-16-2011, 03:34 PM
Originally Posted by jmac698 View Post
I wanted to use this last night, but simply could not figure out where to plug in the source clip.
Nor could I figure out what needed to be changed.
Needs instructions for anybody not fully aware of what's going on in the script.
11-16-2011, 07:22 PM
jmac698 jmac698 is offline
Ok, if you can record my test video to VHS and capture it, I can tell if you're missing any frames
12-06-2011, 05:57 PM
I've put it off for another day. I have other projects that I could / should be working on first anyway.
Looking for VHS capture advice-CBR/VBR, bitrate, res upconversion, dropped frames jtrevor99 Capture, Record, Transfer 9 09-06-2011 03:23 AM
Compression with MMC ATI, P frames and B frames for MPEG-2 ? John Capture, Record, Transfer 1 08-20-2011 10:15 PM
Is there an acceptable rate of dropped frames? maphew Capture, Record, Transfer 5 06-20-2010 09:11 AM
VHS tape malfunction, mechanism not rolling tape properly admin Capture, Record, Transfer 0 10-12-2009 10:57 PM
Need pgm to extract frames from avi mlaviolette Edit Video, Audio 3 04-30-2006 11:06 AM
