08-31-2013, 11:00 AM
juhok juhok is offline
For some time I've been wondering what kind of integrated audio ADC is included in Blackmagic DeckLink Studio (and other BM products). For this test I used RME Fireface UC audio interface for DAC and reference and RightMark Audio Analyzer software.
Results are not definite truths nor professionally controlled and concluded. Further reading about RMAA caveats:
http://nwavguy.blogspot.fi/2011/02/r...yzer-rmaa.html
Balanced Cordial 60cm TRS cable was used for all tests. Balanced circuitry is said to be more noisy than normal, but I didn't want to redo everything to test a tiny change.
Baseline, RME external loopback (+4dB):
http://www.siluriformes.net/dfaq/AN3.../an34-an78.htm
RME (-10dB) -> BM (-10dB):
http://www.siluriformes.net/dfaq/AN3.../an34-bm12.htm
RME (+4dB) -> BM (+4dB):
RME ("HiGain") -> BM (+4dB):
RME (+4dB) -> BM (+4dB +4.8dB gain):
RME (+4dB) -> BM (+4dB +7.6dB gain):
As you can see I tried many types of level matching and it did do some good. Blackmagic control panel settings regarding the audio gain control gave weird results and when I chose to add for example +3dB, in reality the gain changed much less. With higher gain on Blackmagic end I could achieve better dynamic range up to a point. Well, you can see from the results what happens with too much gain. Pretty counter intuitive. As a side note; BM video gain controls also f-up the signal and like I've said before it's better to adjust levels after capturing than with BM's proc amp.
In summary I would say that Blackmagic Decklink Studio has good enough audio ADC for VHS and other home video formats but I would be a bit more careful when doing something more professional.
The following users thank juhok for this useful post: lordsmurf (09-29-2013)
09-17-2013, 05:11 AM
metaleonid metaleonid is offline
What about video part?
09-17-2013, 02:16 PM
I don't have necessary tools to test video.
09-26-2013, 10:20 PM
Still only 2D comb filtering?
09-26-2013, 10:37 PM
Comb is very bad, yes.
The following users thank juhok for this useful post: msgohan (09-26-2013)
07-26-2014, 07:25 AM
Blackmagic card have come up a lot lately, so I wanted to bump this.
adc, blackmagic, dac, rmaa, rme
Decklink Studio - VHS capture (audio pops+black frames) joakim Capture, Record, Transfer 3 11-25-2012 05:36 PM
DV to MP4 - Results in Jittery Video kamil Encode, Convert for discs 3 06-06-2012 12:55 AM
Blackmagic Intensity Pro Flicker Problem P4RL Capture, Record, Transfer 6 05-25-2012 11:05 PM
Blackmagic Design Intensity Pro HDMI and Analog Editing Card metaleonid Capture, Record, Transfer 1 02-01-2012 05:45 AM
Help with Capture Equipment - ATI vs Blackmagic vs Canopus vs Matrox rigama61 Capture, Record, Transfer 8 11-14-2010 11:48 PM
