01-19-2014, 08:27 PM
bfblitz bfblitz is offline
After a fresh install of Windows XP on a Pentium 4 3.0Ghz, I installed a factory CD of Catalyst MMC 7.9 for my ATI 7500 VE. Everything went fine. I then installed Huffyuv. As I went through the Digitalfaq guide for AVI capture using ATI All In Wonder to configure MMC, I was able to make a custom preset using Huffyuv. But the Configure dialog box is grayed out. I have not installed anything else at this point. So, why can't I configure Huffyuv?
01-20-2014, 11:50 PM
When it comes to capturing AVI, VirtualDub is the suggested method. Have you tried it yet? ATI MMC is the second choice for AVI. It's only first choice fir MPEG capturing.
01-22-2014, 11:51 PM
I installed VirtualDub, but it doesn't work with my Startech Via Envy24 sound card. All I get is horrible white noise, pulse noise, and sounds from hell. ATI MMC works fine with the sound card, but the video lags a touch behind the sound. I just ordered a Soundblaster card to hopefully play nice with VirtualDub.
01-23-2014, 12:36 AM
Hopefully that fixes it. If not, come back here and post. We'll solve it eventually!
ATI 600 USB video capture card drivers + Catalyst Media Center [DOWNLOAD] lordsmurf Capture, Record, Transfer 68 08-16-2023 08:04 AM
Uncompressed 8-bit vs 10-bit MOV to Huffyuv AVI? metaleonid Capture, Record, Transfer 4 07-29-2014 06:41 AM
ATI MMC 9.02 with bad Huffyuv AVI? dianedebuda Capture, Record, Transfer 1 01-17-2014 11:32 AM
What version of HUFFYUV 777sp2 Encode, Convert for discs 5 10-06-2005 05:35 AM
