04-30-2014, 07:16 PM
DeeSeven DeeSeven is offline
wow that is a long title
but yeah that is my question. I see them from time to time at my local goodwill/thrift shop but I'd be using it only for transferring. So I can't see a point in getting it..unless I'm missing something?
04-30-2014, 07:28 PM
CCD-based is generally better than CMOS-based for capturing video - its part of the process in the lens for converting light into digital info. For capturing, it should have no effect on quality.
04-30-2014, 09:00 PM
If you aren't recording video, the image sensor really doesn't matter. 3CCD doesn't always mean better video quality. Low light performance takes a big hit since there is a prism that splits the incoming light to the three sensors .
05-01-2014, 04:54 AM
Is a 3-CCD cameras better? Yes ... but only because the 3-CCD cameras are usually better higher-end cameras. And the single CCD cameras are the cheaper ones.
It reminds me of the megapixels myth. "More is better!" ... but it's really not.
I still remember the Canon ZR series of DV cameras, which "only" had single CCDs. But those cameras often outperformed the Panasonic 3-CCD cameras. Why? The sensor was better. And that's what really mattered.
05-01-2014, 11:57 AM
thanks for the reply ls
05-09-2014, 06:27 PM
As noted above, for capture of MiniDV tape via IEE1394 (aka: firewire, iLink) the number of CCDs does not matter. If using the camcorder as a video camera to capture a live scene it will depend on the the specific gear, the scene, and lighting conditions. Within the same generation of equipment and brand name 3 CCD will generally be better for most purposes.
Be sure you give any thrift shop camcorder a good test before spending hard earned dollars.
05-09-2014, 07:25 PM
thanks dpalomaki I'm actually the nerd who brings 8mm/hi8/minidv tapes with him when going to thrift stores to test stuff I've been down that road once already lol
05-13-2014, 02:49 AM
I do that almost anywhere for any reason.
Storytime...
A month ago, I sat on the floor at Home Depot, pulled out a pocket full of parts, an exacto knife, and opened a ceiling fan box. We partially assembled it on the floor, and made sure it all worked. We actually opened 3 different ones, and 2 did NOT do what was needed. We boxed them back up, then bought the one that worked.
What was funny was several employees would walk over, never say a thing, and look at what we were doing. They never offered to help, asked what we were doing, etc.
Remember: It's always best to ask for forgiveness than permission. Had we asked "can we open this", they may have said no. I didn't give them that chance, and did what I needed.
Longer story: This was day two of our ceiling fan ordeal, as the first salesman told us BS that wasn't true, and we had to return it. I refused to assemble another fan on the ceiling again, only to take it back down! Huge PITA!
(And if you need a ceiling fan, the Home Depot in-house brand Hampton Bay fans are whisper quiet. The so-called "quiet" Hunter fans are crap. They make grinding noises in the motor, and are more expensive to boot. They're therefore doubly bad! This is our 5th Hampton Bay. No, not replacements, all 5 are still in use.)
Anyway, good for you.
The following users thank kpmedia for this useful post: DeeSeven (05-13-2014)
MiniDV camcorders as TBC? + VCR questions vhsdigital34 Project Planning, Workflows 45 07-20-2014 07:54 PM
Help planning my workflow: 8mm, Hi8, DV, MiniDV, VHS Lightsword Project Planning, Workflows 3 05-06-2014 08:50 PM
Transfer MiniDV tape to Mac or PC? Eagleaye Capture, Record, Transfer 11 07-17-2013 11:35 PM
VCR -> MiniDV (passthrough) firewire -> Mac? stuckinstandby Capture, Record, Transfer 1 12-06-2011 06:42 PM
From Sony MiniDV to final DVD ravid57 Capture, Record, Transfer 29 10-01-2004 11:15 AM
