03-27-2017, 01:15 AM
Maris 55 Maris 55 is offline
Hi,
I wanted to clean the heads of my Blaupunkt and because I don't have Chamois I accidentaly found what I think is a very good material for this purpose. You know inside the CD/DVD disc bundles there is a white plastic damping ring. This is a soft, matt, flexible material with slight moisturing capabilities in about 5cm in diameter. I gave it a try and liked it very much. There is no fear for lining (?) or catching the edges of the heads as the material seems to have all the right qualities. And don't think it is just like foam, it's not.
Blaupunkt RTV-950, LG LV-880 HiFi, Sony miniDV ..., Canopus ADVC 55, WinDV,
03-27-2017, 07:21 AM
https://www.amazon.co.uk/MG-Chemical...+swabs+chamois
03-27-2017, 07:56 AM
Thanks for the link! I know that they are fine, but until I have bought them I discovered that these plastic rings from CD bundles are very well suited too.
Seeking JVC HR-S3500U head cleaning advice elpablo1 Video Hardware Repair 3 06-08-2016 11:02 PM
Do you keep your source material after capture? premiumcapture General Discussion 6 06-15-2014 07:39 AM
JVC SR-V10U head cleaning? JT_too Video Hardware Repair 1 02-15-2014 12:45 PM
Ditene system and Betacam material Giana Capture, Record, Transfer 1 01-17-2012 09:51 AM
Tapechek Pro reviews? Good for cleaning/repairing VHS tapes? Kenneth M Restore, Filter, Improve Quality 4 01-09-2009 05:26 PM
