04-18-2019, 05:28 PM
ELinder ELinder is offline
Unconfirmed User
What's OBS?
My Pinacle 510-USB audio level can't be changed either, so in that respect the VC500 isn't unique. The control is there for both in Windows Mixer, but changing the level does nothing and the Apply button is not active.
I picked up the VC500 because the video on my 510 has been acting up since I dropped it last week. Well, if worse comes to worst I can always capture twice and use the video from the VC500 and audio from the 510 since it's loud but distortion free.
Unless someone has advice on finding a good revision of the VC500 or other USB capture that can control the audio level?
Erich
04-18-2019, 05:54 PM
OBS = https://obsproject.com
But it's not really a capture software, more of a streaming software.
The 510/710 are what I referred to as boxes where you cannot adjust, but really do not need to, as the values are about 50% already.
Again, ATI 600 USB can be controlled via registry hack.
03-19-2020, 03:33 AM
robertzombie robertzombie is offline
A passive pre-amp would solve this problem. Something like this: https://www.monacor.com/products/pa-...ls/ila-100rca/
Insert between the VCR's audio output and the capture device's audio input.
Diamond VC500 USB and VirtualDub to capture PAL? Bobban Capture, Record, Transfer 27 04-01-2017 08:02 AM
Diamond VC500 won't capture with VirtualDub and Win10 SoManyTapes Capture, Record, Transfer 5 01-03-2017 07:17 AM
Audio out of sync after VirtualDub pinheadlarry Encode, Convert for streaming 23 12-20-2014 12:54 PM
Problem with ATI TV Wonder 600 USB in VirtualDub - no audio? Zoink187 Capture, Record, Transfer 7 07-21-2014 04:26 AM
No audio when capturing with VirtualDub TylerDurden389 Capture, Record, Transfer 17 04-15-2014 05:27 PM
