07-22-2018, 06:01 PM
koberulz koberulz is offline
My captures show 0 frames dropped, 0 frames inserted, but then I get things like this happening.
It was fine for like an hour, and then that really bad stretch showed up. It's happened in a couple of other tapes as well. The original tape is fine, as I have a different capture that doesn't show the issue.
07-24-2018, 08:44 PM
I see it.
We just need to review your entire workflow again.
Describe your chain, all hardware (video and computer), software, etc.
Start there.
07-24-2018, 10:08 PM
It's happened with both a Panasonic NV-HS1000 and a SR-S388E connected to a Panasonic ES10. Through a USB-Live2, into AmarecTV on a Windows 10 laptop, captured onto a RAID0 via USB3.
07-24-2018, 10:47 PM
The VCR is probably not it, and existing on two different decks eliminates those.
Remember, and ES10 is not a TBC. Perhaps it's interacting poorly with your tapes? Try to bypass it.
You do have a TBC, right?
Capture card possible.
Amarec is not as tried and tested as VirtualDub, so I'd suspect it as well.
RAID-0 can cause issues with video, and I said that over 15 years ago. I saw issues as far back as 2001. However, less likely here, due to frame duping.
Windows 10 is a mongrel, but again unlikely here.
Time for process of elimination. ES10 is main suspect for the moment.
07-27-2018, 03:28 AM
Oops, forgot about that. There's a TBC-1000 before the capture device.
I used the ES10 because the picture was tearing when using the built-in TBC on the JVC and Philips decks. I didn't use the ES10 when capturing from the Panasonic deck, I realise now my phrasing was ambiguous on that point.
VDub doesn't work at all, which is why I used Amarec. Can't remember what the issue was offhand but I probably posted about it on here.
EDIT: Pretty sure this issue was what led to me dropping VDub: http://www.digitalfaq.com/forum/vide...ive2-proc.html
It's also not a constant thing, this seems to be the only time in the entire 1:45 tape that it happens.
Inserted frames in VirtualDub after new PC build? thestarswitcher Capture, Record, Transfer 8 07-12-2018 08:03 PM
Inserted frames in VirtualDub? (Argh!) thestarswitcher Capture, Record, Transfer 5 07-01-2018 02:08 AM
Trying to Understand Inserted Frames premiumcapture Capture, Record, Transfer 10 04-17-2017 06:59 PM
What are chances an external frame synchronizer tbc improves a signal with no dropped or inserted frames in vdub? quad4k Capture, Record, Transfer 0 07-23-2013 11:23 PM
VirtualDub - frames inserted? lookouts Capture, Record, Transfer 3 10-15-2006 09:28 AM
