11-05-2009, 03:51 PM
Superstar Superstar is offline
Is there something that I can do, or add to my computer that would make the encoding process in MC go faster? For a 3 hr video, it takes about 9 hrs to do, what's weird is, for a 2 hr video, it takes 3-4 hrs to do...I thought that's kinda odd
I do a lot of 3 hr videos and that 9 hr encoding time kills precious time, so can I add or replace anything to speed that up, or would I have to get a whole new computer?
11-05-2009, 04:02 PM
Be sure all the settings are correct, such as resolution, interlace, etc. If it takes 4 hours for a 2-hour encode, it should only take 6 hours for a 3-hour encode.
Beyond that, know that CPU and hard drive speed are the two bottlenecks. RAM is barely used. Adding RAM does nothing.
You'd have to add a new high-end computer to up the encode speeds. I can get maybe 100fps MPEG-2 on my quad-core, in MainConcept. That means a 2 hour video takes maybe 45 minutes.
You can always buy more computers, and use a KVM!
11-05-2009, 04:12 PM
"Be sure all the settings are correct, such as resolution, interlace, etc"
Do I check these settings in MC, if so, where at?
11-05-2009, 06:14 PM
Click on some stuff and look around. There's not much to it. I want to teach folks, but I also want you to take some initiative and research/test/experiment. Play with things, look around. The computer won't explode.
"Teach a man to fish..."
A lot of this has already been covered in some of the many, many threads we've had in the past many months, going over your project.
11-05-2009, 07:12 PM
Well...I can't look for something, unless I know what I'm looking for lol. I'm using the settings that you gave me to use before..
(When I'm encoding)
mpeg 2
elementary video
video mode- ntsc
detailed settings-
width 352
height 480
check by keep proportions
check by 2 pass encoding
frame rate 29.97
field encoding - top field first
advanced mpeg settings
frame rate - 29.97 fps ntsc, non drop frame rate
apect ratio - 4:3 display
bitrate type - variable
rate mode control - mode 1
When Not Editing Audio -
Mpeg type - mpeg 2
stream type - program video & audio
video mode - ntsc
audio mode - layer 2
Adv mpeg settings
Audio type - mpeg layer 2
bitrate - 256
(all other settings are the same as i listed above)
Does all of that look good?
11-05-2009, 07:25 PM
Looks good.
Re-encoding (re-DCT) video tests admin Encode, Convert for discs 2 12-11-2010 08:41 AM
Color after Encoding on burned DVD Superstar Restore, Filter, Improve Quality 1 08-20-2009 05:36 PM
Procoder - Need help Encoding settings Tom_n_Jonna Encode, Convert for discs 10 12-22-2007 08:46 AM
Encoding Question Tom_n_Jonna Encode, Convert for discs 1 10-29-2005 10:56 AM
Procoder 2.0 encoding has macroblocking blazey Encode, Convert for discs 7 02-11-2005 11:57 PM
