Quantcast How to burn or convert AVI to DVD easily? - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Encode, Convert
10-07-2010, 10:48 PM
zhanghao zhanghao is offline
I want to burn a movie to a dvd but the problem is that this movie is in the .avi format.)Is it possible to burn a .avi file to a dvd. Also tell me how to get this to work. are you familiar with any program which will help me in this matter. Please suggest a suitable burner application.
Appreciate your early reply so much...
10-08-2010, 12:51 AM
The answer found at Convert an .wmv file to a playable dvd would also apply here.
Specifically, this post:
For a quick-and-dirty DVD, using freeware, there's always AVStoDVD.
But it has some limitations that I don't much care for. For example, limited menu background and the inability to make menu-less discs. Same for video cropping and aspect ratio options. In fact, there are not many options at all. You just plop a video into the window and hit "go" and hope it works well. Yeah, it's free, but you get what you pay for.
Better software would be ConvertXToDVD.
Or as runner-up choice, the AVS Video Converter.
Both of those are in the $50-60 range, and have quite a few adjustable options for menus, quality, etc.
I use ConvertX pretty regular, for certain tasks. In general, for converting video that I downloaded off Youtube or Hulu, and want to watch on an actual TV at my leisure. (Usually a small kitchen TV, given the quality of that source.) The converted video looks good. Maybe not quite as perfect as manually encoding in Procoder or MainConcept, and then authoring a DVD, but this is quicker. It's a nice option for times when it just needs to be a good DVD to watch, and not necessarily a professional production quality output.
__________________
If this site has been as helpful as a book or magazine, then Donate a few Dollars or Upgrade your Membership.
10-08-2010, 10:07 PM
asdttk asdttk is offline
Hello,zhanghao~I suggest you can use a video converter which call ConvertXtoDVD. You can Convert & Burn your videos to DVD,and backup and transfer your movies to DVD and enjoy watching them on any home DVD player.
10-08-2010, 10:48 PM
If there are any program dont pay or i can try out its trail version?
Someone recommended nero for me.
Comments have been removed from this post. The Digital FAQ does not allow the discussion of unauthorized software. This includes unofficial acquisition methods (torrents or 'file sharing') as well as unofficial registration methods (keygens or cracks). If your budget does not allow for the purchase of payware tools, simply limit yourself to freeware options. Thanks for understanding our tech Q&A policies.
Last edited by admin; 10-10-2010 at 04:06 AM. Reason: Discussion of using keygens is not allowed.
10-08-2010, 10:50 PM
Thanks for your reply.But i dont want to pay $50 for this program.By the way, i am looking for free sofware.Any more suggestion?...
10-10-2010, 04:09 AM
You saw that AVStoDVD was free, right? Download that from http://sourceforge.net/projects/avstodvd. If you have already tried it, then mention what you did or did not like about it. Based on that feedback, other programs could possible be suggested.
Still want more? Sothink has some free options: http://www.sothink.com/product.htm#free
However, we're not done with our testing/review of the Sothink video conversion apps, so we're not ready to suggest them just yet. Site staff only recommends software that has been vetted and tested, and meets our quality standards on how video software should perform.
Regarding Nero, read this: Convert an .wmv file to a playable dvd
It has already been explained in that post why Nero is not suggested.
Thanks.
__________________
12-27-2011, 03:49 AM
Andiefang Andiefang is offline
You can use an avi to dvd converter , just looking for a professtional converter , it is an easy job , you can do it yourself following the steps . so find it and have a try .
avi, dvd, movie files
Deleting PM spam easily on vBulletin kpmedia Web/Print Publishing Technology 0 01-25-2010 03:19 PM
Bitrate is too high to burn? Superstar Author, Make Menus, Slideshows, Burn 10 11-13-2009 03:40 PM
Burn HD-Content on a normal DVD on a MAC admin Project Planning, Workflows 0 09-08-2009 09:37 AM
Bad burn with Fuji Taiyo Yuden, what could have gone wrong? MagnificentMarcus Blank Media 18 09-14-2005 06:42 AM
How to burn extras onto a DVD markatisu Author, Make Menus, Slideshows, Burn 0 06-02-2005 10:00 PM
All times are GMT -5. The time now is 03:10 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
