03-14-2021, 10:50 PM
pizzarat87 pizzarat87 is offline
Currently I am using a Panasonic DMR-ES25 DVD Recorder as a pass-through to my DVD iScan DUO for my Panasonic LX-H670 Laserdisc player and JVC SR9800 VCR. As I quickly discovered, I cannot use the HDMI output from DVD Recorder to the iScan DUO as a I get a "content protected" error.
I now plan on buying a DMR-ES15 based on Lord's Smurfs posts, but in the mean-time I am trying to get familiar with the current recorder as I'm sure most of the settings are the same.
1. Which video output should I use from the DVD recorder to the iScan Duo? Composite, S-Video or Component?
2. Any recommendation for video settings on both units? I currently have DNR turned off on the recorder, and the composite output from the Criterion Ghostbusters LD looks really good.
3. In the "Video" sub-menu there is also "Progressive On/Off" and "Transfer Video/Auto1/Auto2". Which should be selected?
4. In the TV Screen sub-menu should I select "16:9 & (480i)" or "16:9 & (480p)" knowing that I am outputting to a video processor?
5. Any general tips on general video properties like brightness/contrast/saturation? I read that the Panasonic recorders can be slightly dark.
6. Should I be using any specific settings on the iScan Duo like mosquito reduction?
7. since the DVD recorder does not have optical audio in, I am going directly from the player to the iScan Duo. The Duo apparently automatically compensates for the audio delay, but should I set it back since the video is going through the recorder?
Thank you very much for your time.
dvd recorder, iscan duo, laserdisc, output, settings
JVC HR-S7711 SECAM to PAL input-output settings? halopower Project Planning, Workflows 1 11-01-2020 11:19 AM
Recording Settings for VCR/DVD Recorder crissrudd4554 Capture, Record, Transfer 4 08-24-2020 11:01 AM
Toshiba RD-XS34 DVD Recorder no video output cdg123 Video Hardware Repair 1 12-14-2019 09:59 AM
ATI MMC gamma settings affect final output? rocko Capture, Record, Transfer 6 06-20-2015 12:52 PM
DVDO iScan Ultra Home cinema Video Processor review ? deter Capture, Record, Transfer 2 12-30-2011 01:08 PM
