12-20-2010, 02:19 PM
continued from PM...
NOTE: Rather than "waste" advice in private, I try to share as much as I can on forums so that others may gain from my information.
Originally Posted by jesse51786
Thanks for replying on my thread. To your point about using a better VCR, I tried a couple which play other tapes with no trouble at all, and both show significant distortion at a couple certain points. Do you have any software recommendations for doing this sort of frame replacement that I'm looking for? Thanks again for your help.
I'd have to hear more about the entire project one more time, in order to know what it is that you're going for. Reply here with a quick overview on what you're doing, and where you're going with it, and I'll see what I can do to help further you along.
I can see the original post you had made:
Hi all,
My family has a bunch of old videos on VHS that are basically slide shows of family photos set to music. Since they've been stored on VHS for years now, I've taken it upon myself to finally get them converted to digital format to prevent further degradation. I bought a USB capture card, and I used Windows Movie Maker to get the videos in .wmv format from the VCR. I've noticed that there are a lot of bad frames (lots of grain appearing in the middle) in the videos. Now, I'm thinking that, since there are no real action shots (just flipping from one photo to another, with music playing), can I replace one bad frame of video with a good frame that appeared before? Here's an example... music is playing... photo appears for 10 seconds. 5 seconds in, grain distorts the image for a couple seconds. Can I replace those two seconds worth of footage with footage from the first few seconds? I'd really appreciate any advice you might have on this.
Jesse
... and my response was to use a better VCR.
Specifically, one of these models: http://www.digitalFAQ.com/forum/show...-pre-1727.html
There's really no fun/easy way to replace bad frames, aside from exporting the video to many, many, MANY, thousands of still images, and then deleting bad frames (and then replacing with copies of adjacent frames). You'll have to deinterlace the video before all of that, too, and the best quality may require Avisynth (Yadif/Yadifmod+NNEDI2).
The idea behind the better VCR is to preclude the need for frame replacement. With a better VCR, the tape may simply play without any further problems.
Just reply here to this post, for further help.
Thanks, -LS
12-20-2010, 05:17 PM
If I understood the problem correctly, wouldn't it be "easy" to just choose the best frame from each shot, export it to still image for example, save the soundtrack, then redo slideshow using the stills + audio? With luck the stills are in "progressive" form saved as two fields. I admit I use Avisynth and such daily and I'm blind to some obstacles people may have, but Nero etc used to have wizard for slideshow making (after the stills are acquired) and I'd guess nowdays there are even more alternatives than near decade ago I last needed slideshow. Also if it's just a few tapes it might be cheaper to get it professionally done? Tho my guess from jesse51786's description is that upon viewing the tapes people have paused the frame for extended periods of time (maybe 10 seconds wasn't enough?) and the tape is damaged in that area permanently?
12-20-2010, 11:22 PM
Yes, actually, this would be better. When I wrote the above post, I had completely overlooked the details on the source. Indeed, it would be easiest and fastest to simply remake the slide show by grabbing one good still. The only "problem" will be matching the duration of the old and new slides, if they are (for whatever reason) not simply equal-length time on screen. For example, a fancy sync to music, with (as another example) some slides showing for 5 seconds, or others showing for 10 seconds.
Unlikely. The video file will likely have to be pre-deinterlaced, coming off VHS source. Then again, it really just depends. If 2-3 fields are "frozen" on top of each other in a frame, and the video quality is good enough, it's visually the same as progressive.
Yes, indeed. You would not want Nero. AN excellent slideshow program these days is the very low-cost MemoriesOnTV4. It's $60 for home edition: http://www.codejam.com/slideshow/index.htm ... and it's great for web-based slideshows, too, not just DVDs.
12-20-2010, 11:26 PM
We're actually in the middle of doing a project very similar to this, but from extremely damaged digital sources, due to a DVD/MPEG-2 camera that was malfunctioning. Of course, it's an irreplaceable event that was filmed. The new "film" is going to be built from a mix of still-good video, some extracted video stills, and other photos from the event, with the original soundtrack (enhanced, denoised, cleaned up/filtered), and turned into a new master DVD for distribution.
It's a mess, to say the least. An expensive one, that takes a lot of work in editors.
12-23-2010, 01:13 AM
Hello,
I would like to offer an alterative approach to your problem. This technique will, in software, find the good stills and freeze-frame them, therefore recreating them, automatically and with no other changes in length or synch with audio. This is very easy to do and needs no fancy equipment.
If you would like to upload a small sample of your video, enough to cover four slides (and noise in between), I can verify my technique. The quality should be the largest visual dimensions, but the lowest file size/highest compression/lowest bitrate - I'll have to take a look at the moviemaker screen to see what setting that would be (but I don't have Windows 7 so I can't help you in much detail).
Much as you thought, with software you can select one good still from each group. Stills are by their nature progressive, I don't understand the comment about them needing to be deinterlaced (except, I mean to 'deinterlace' the stills by treating them immediately as progressive).
For the experts: I was thinking of using this Avisynth filter: http://neuron2.net/dup/dupnew.html along with some scripting. You will see that this software selects the first frame in a string of (assumed) duplicates and freeze frames it. It will pass through the noisy parts by default as they are not detected to be stills. So what we need is a way to deal with the noisy bits. The answer could be quite simple. First, run the detection of what is a still frame on the very top of the video where the noise never appears. Another idea is to use a periodic timing where, the first still in a group is freeze-framed and then all video is ignored for the next 10 seconds, and then the search for the next still begins again.
It's possible there's an even easier case, where the stills are exactly 10 seconds apart in which case you can simply select 1 frame out of every 10 seconds, and duplicate them out to 10 seconds again. The sound is left untouched. If the stills fade in or use a fancy special effect, then the few seconds of that effect are kept and then the last frame in the sequence is freeze-framed.
12-23-2010, 03:31 AM
The tape has interlaced the stills to VHS format -- that's all it is.
Windows 7 isn't much different from Vista, aside from having an interface that's a nuisance. And tries to hide files from you with that silly "compatibility view" storage method -- hate that about it. (Stick to XP if you can, Vista if you must, but avoid 7 if you do lots of file management and video work!)
What would be a sample script for the Avisynth?
12-23-2010, 04:58 AM
I could make a theoretical script for a certain imaginary problem, but really I need to see his video.
Just think of it this way, let's say you can detect a still frame. Then what is the logic of fixing his problem? Just;
1 wait for still frame
2 freeze frame that until further notice
3 wait for different still frame
4 go to step 2
All you need then is a way of detecting a still frame, a way of comparing two stills to see if their different, a way to generate freeze frames.
So you find a plugin or create your own technique for each of these parts and put them together. I hope this gives you an insight into scripting, it's like making a "video program".
In real terms you'd have to use ScriptClip to process this frame-by-frame.
