10-27-2015, 04:31 AM
Goldwingfahrer's Avatar
Remembered
Hello
I have topically the DMR EH65 on the place Capture. and now tests JVC HM-DR10000.
he is completely sufficient if I there by HDMI to my Blackmagic studio 2 maps goes.
http://www.ggvideo.com/bm_bdlkstudio2.php
I need Kramer SP-11D only for colour movements and for the norm changes PaPal to NTSC or return.
With Avisynth I can shift the colours also and also norm changes. Unfortunately, not on a real-time basis.
With the DMR EH585 DNR do not forget switch off and put the other settings properly.
I have external TBC only those of Electronic design E and one of Snell & Wilcox.
I have ordered an AVT8710 three weeks ago from the USA... I wait and wait; - (
The following users thank Goldwingfahrer for this useful post: U-max (10-29-2015)
10-29-2015, 01:29 PM
U-max U-max is offline
Ok, thanks for your suggestions. In the meantime the Pana has arrived. I will try it within the next few days. I'm waiting for a Snell & Wilcox TBS100 Kudos Plus unit as well. I'll post the results.
10-29-2015, 05:26 PM
Remembered
Try it without TBS100 only with the Pana DMR......... You get such a result, see picture.
The Snell & Wilcox expects a perfect signal FBAS.
The Consumer recorders are not able to do something like that.
Here are able to do it only the big Pana AG/AG-MD and the JVC-HR-Sx22 recorder.
Unfortunately, only the least tapes have been recorded earlier with these recorders.
11-04-2015, 12:38 PM
S&W TBS100 indeed works great only if I connect a very stable source like a Sony DVD player through S-VIDEO, while if I connect the JVC and/or the Sony tape decks it won't handle any input signal. Maybe adding reference inputs, 625 BB or composite, should work but I'm not equipped enough. What a pity!!!
Pana DMR EH-585 works great instead! I've connected the JVC HR-S7611 through SCART input (S-VIDEO MODE - AV2 on the rear panel) and the Sony VP-7040 through composite inputs (AV3 on the front panel). Is there any way to prevent the blue screen while capturing blank frames from tapes?
Do you suggest to always keep NR in/out disabled even with unstable sources (as like U-matic for example)? And what about the Progressive out? I'm wondering whether I should enable it or not...
Did you get the AVT8710?
11-05-2015, 10:40 AM
Remembered
no and this is out well thus... one cuts in the Postpro
I have off NO. always.
Progressively = no [after in Avisynth if I has to go]
normally there remains in interlaced.
Yes, however, the AVT8710 is first 3x around the world travelled to him with me has come.
Totally price 311 SFR. [converted about 320 USD]
However, he is only tested... compared to
the Canopus NX
and AVT8710-> Datavideo DAC 7-> SDI-> Blackmagic studio 2
and AVT8710-> DMR EH65-> HDMI out to Blackmagic studio 2 maps.
3 Streams with Edius 7.50 [Edius 8 per are opened still lies in the box]
see picture in the appendix
[Films are looked of course not in the PC monitor, but in real interlaced studio controlling monitor CRT.
1. Impression of the AVT8710 = not so fantastically, although "Automatic Gain Controll" should function.
Will show later 2 comparisons in a new contribution.
Original becomes in UYVY or in YUY2 capturt.
For Internet I will encode the Streams, however, in mpeg2.
about in 8000 kbps and in TFF.
11-16-2015, 09:00 AM
Hi Goldwingfahrer, I've got a problem. Intensity Pro 4k won't recognize HDMI input from the Pana and the Pana won't allow me to change the HDMI settings (options are greyed out as you can see in the attached photos). I don't use any splitter between them (I think I don't need it).
Otherwise, connecting the Pana to a LCD TV via HDMI everything is ok and the settings are enabled. Via S-VHS it's also ok. I have tried to change HDMI cable but still won't work.
Do you have any idea how to solve this problem?
Thank you mate.
11-16-2015, 10:52 AM
Remembered
Hello.
Only with the correct HDMI Splitter it works.
We tried everything.
Here is a little film in PAL Mpeg2, setting in Italian.
Supplement ...........Almost forgot.
I have directed the CVBS signal to my control interlaced monitor from DMR EH.
Because I see the settings and can adapt that.
In the Blackmagic software that will not do.
The following users thank Goldwingfahrer for this useful post: U-max (11-16-2015)
11-16-2015, 11:08 AM
Gosh! I thought I could connect them directly... ok. So, what kind of splitter do you suggest? Which specifications should it have? P.S.: I don't need to connect the LCD display anyway.
Thanks again.
11-16-2015, 11:48 AM
Remembered
This splitter as in the post 487
http://forum.gleitz.info/showthread....ghlight=Kramer
or
http://www.ebay.de/itm/HDMI-Splitter...3D160848002793
Output 1 = ---> BM 4K
Output 2 = LCD or plasma to
  #30
11-16-2015, 01:20 PM
OK danke vielmals!
In the end I got this one...
http://www.amazon.it/gp/product/B00SYBZIEU?psc=1
Actual workflow:
U-MATIC SONY VP-7040 - composite \
S-VHS JVC HR-S7611 - scart (s-vhs) | PANASONIC DMR-EH585 - Splitter HDMI -> IP4K
BETAMAX SONY SL-C30E - composite /
Finally I can capture footage with astonishing picture and sound!!!
11-23-2015, 05:46 PM
Remembered
Great.
Exactly what we wanted, yes.
Thanks for the feedback.
From Betamax I have only 2 recorders, Sony.
SLV-150 HF + SLV-950 HF SB [Super Beta]
My colleague Michael also repairs Betamax
http://www.wedemann-service.homepage...ge/betamax.php
11-23-2015, 07:44 PM
Ja, natürlich! Danke, mein freund!
Thanks for the link!
P.S.: vielleicht haben sie zu sagen, meinte SL-HF150 und SL-HF950?
11-24-2015, 03:20 AM
Remembered
I do not understand.
I wrote that I only have these two have of Betamax.
Translation is difficult.
In the next life I'm learning English;-)
11-24-2015, 04:15 AM
I really want to learn German.
11-24-2015, 05:04 AM
Using better Google Translator would be a good start... I guess...
Diamond ATI 600 PCIe black/green screen video input? dad2 Capture, Record, Transfer 1 02-12-2018 06:38 AM
Component (Red,Blue,Green) to s-video adaptor? rocko Videography: Cameras, TVs and Players 1 05-16-2015 10:25 PM
Issues with removing video noise? dbvilla Restore, Filter, Improve Quality 4 02-10-2015 10:46 PM
Broadcast Grade TBC - Kramer SP-10D meson1 Restore, Filter, Improve Quality 8 06-21-2013 12:29 PM
Green screen video on latter VOBs admin Encode, Convert for discs 0 05-21-2009 06:04 PM
