12-05-2015, 03:36 AM
I've recently gone back to transferring some old VHS tapes to DVD. I've done a few in the past but those were before I got my ZT60 flatscreen. My DVDs look fine on my trusty JVC CRT but when I put them on the Panasonic it can be painful to watch at times. I understand the sheer physical limitations of the media but I was wondering if there were anything I could do to improve matters somewhat? I'm not expecting miracles mind you just wanting to know if I can make it better.
Currently my transfer setup is fairly straightforward. I use a JVC SR-V10C that I purchased from TGrant photo (highly recommend this merchant) feeding into a Toshiba DR570KU. I am using the S-VHS feed on the video line.
I've read several other threads on this and other forums but the availability of information is almost overwhelming particularly to someone trying to get a handle on a good starting point on their particular situation. I thought I would post the question here and see how I fared.
Any assistance is appreciated and I'll be glad to provide any additional details.
12-06-2015, 03:33 AM
You need to define what ""it can be painful to watch" means. Describe the issues you're seeing.
Decent JVC S-VHS VCR, yes. The SR-V10U is actually better at EP than the 7000/9000 lines.
s-video is best, yes.
I'm not sure about the quality of that Toshiba recorder. I think that's one of the latter Funai rebadges, and those aren't great machines.
I notice the lack of TBC.
Perhaps post a sample clip of the bad footage.
12-06-2015, 05:28 AM
I thought the SR-V10U had an integral TBC. I've always had good luck with the Toshiba. I think my problem is going from a 27" CRT to a 65" plasma.
What DVD recorder do you recommend? I picked the JVC deck up based on your recommendations.
I will try to post footage later.
12-06-2015, 06:27 AM
External framesync TBC is not the same as internal line TBC. You need both.
JVC also made excellent LSI Logic based DVD recorders. Be aware that only certain models are good, not the JVC brand in general.
Post the footage, show us your errors.
12-07-2015, 09:37 AM
Does the Panasonic DMR-E30 have the LSI chipset?
12-20-2015, 10:13 PM
Originally Posted by Goldwingfahrer
Yes I know that but I'm trying to find out if the Panasonic DMR-E30 has the LSI chipset. Does anyone know?
12-21-2015, 12:56 AM
Remembered
I believe that the changeover to "LSI" was made in the year of 2005.
My first Pana was the DMR E100H [2003]
At the moment I have only DMR ES10 + 15 / + 595 DMR EH65
and a DMR EX98V.
All other I've sold or brought to the cemetery.
I think that using an LSI chipset only the newer model with 720 x 576 [480].
All DMR with 704 x 576 [480] does not have built-in image resolution LSI.
Here, perhaps, find what exactly
http://www.avsforum.com/forum/106-dv...-features.html
12-21-2015, 07:38 AM
No. The ES-20 was the last Panasonic to use the LSI chip. All others used Panasonic's own.
Recording VHS directly to DVD is a convenient way of doing it, but only high bitrates are recommended even if you have an LSI chip onboard. Direct VHS to DVD does nothing to reduce many VHS noise problems -- at least recording at high bitrates gives you a workable MPEG that can be cleaned up and re-encoded.
There are other considerations. The ES10 and ES15 had more powerful line tbc's and frame sync correction, but later models steadily decreased in the quality of those features.
There's another factor, and very important. The Toshiba DR570KU is a DVD/VCR combo. The brand name doesn't matter, as none of the major OEM names have made their own players or recorders for several years. All combo units are pretty much alike. The JVC player is a step up, but the recorder section itself isn't a "real" Toshiba. Another factor is the condition of the tapes. If you want VHS to look as clean as digital, a DVD recorder won't do it for you. VHS will never "look like" a DVD original for several reasons, but with some post-processing work they can look infinitely better than the noisy original. Another factor is Panasonic HDTV's. I've never cared for them or their pumped contrast and pushed reds, and they don't handle interlace or telecine as well as a few other TVs like SONY or Samsung (although Samsung has frequent quality control problems). By the time CRTs began to disappear they'd gone through decades of refinement, so tapes looked better on those monsters than they do on LCDs. LCD's are far more intolerant of noisy input. Sharp-eyed users have always known this, which is why so many people held on to their CRTs. I know many who still own them. But keep in mind that even if you'd had a 60" CRT you'd see problems magnified.
Still, you can always improve those recordings but it takes some work.
As lordsmurf suggested, we don't know what "painful" means. We'd have to see a short edit of a few seconds of video to advise. DVD content in the VIDEO_TS folder on a disc can be copied directly to a PC to make short edits. However, the content is in the form of VOB files. These are MPEG2 encoded, but you need smart-rendering editors to make a sample without re-encoding the cut. A cleaner way to transfer DVD content to a properly organized MPG file is to use the free VOB2MPG. If you want to do any cleanup of the video, you'd need VOB2MPG anyway. A group of VOB files themselves are not very convenient for that work.
Either way, whether you copy VOBs to a PC or get an MPG using VOB2MPG, you can easily make a quick, unaltered sample with the free DGIndex utility in DGMPGDec, which works properly with VOBs and MPGs. You would need a sample of about 10 seconds of video with some motion involved, such as people or objects moving, gesturing, etc. (just a talking head, unfortunately, doesn't have enough variation to see the problems). DGIndex can make a cut on I-frames and does not re-encode the output file. It's a free standing utility that needs no Windows installer. There is a tutorial that shows how to use it and make a sample video here: http://forum.videohelp.com/threads/3...=1#post2272359. The explanation takes longer to read than to actually do it. A 10-second or so MPEG cut would be a file size well within limits for uploading directly to the forum.
Without a sample, there's not much more anyone could say.
12-21-2015, 09:16 PM
Thanks for the replies everyone!
sanlyn my Toshiba is a DR570KU but it is not a VCR/DVD combination unit. It looks like the one here--
http://www.manualslib.com/manual/203...a-Dr570ku.html
I've been meaning to upload a sample but have just been too busy.Does it matter if the tape is a commercial one but one that is not available on disc in its original VHS form?
12-21-2015, 10:11 PM
Oh, yes, yet another variation of the 570's. It's the same recorder section used in the 570 series. They differ in tuner sections, HDD size, etc.
If the you made the DVD from a tape you own or made yourself, posting isn't a problem. Be sure to use either DGIndex or a smart rendering editor like TMPGEnc Smart Renderer to make samples that won't be re-encoded. DGIndex is the easiest way to get a quick sample, either from mpg or VOB copied to your PC.
12-31-2015, 12:02 PM
I still plan on posting some footage however I think some of my issues were due to forgetting to alter some settings that would improve the quality of the image on playback.
However, I was wondering how I can go about re-centering the image about 7 pixels down to hide the overscan/head switching line without re-encoding. Is that possible? I did a search but nothing really helpful came back unless it's my search parameters at fault. Any advice appreciated.
12-31-2015, 12:30 PM
Remembered
Most broadcast recorder can cover the area.
or
Elro VL 300 / Elro VL220
Video Fader = okay
Sharpness = ask only to zero
I've tested both here and also
Here I cover the edges off until after the capture.
Either in Edius or via Avisynth
12-31-2015, 02:45 PM
Use the pan&scan (zoom-in) option with a player like MPC-HC, it's free and no reencoding
01-01-2016, 05:56 AM
Remembered
themaster1
The question was
VHS to DVD ... headless switch Noise [ohne Kopfumschaltbereich]
Not to Soft Player
01-01-2016, 02:26 PM
Panasonic implementation of LSI was awful. The chip was poorly used.
01-02-2016, 04:17 AM
So you're saying the ES-20 is garbage then?
You know it's getting kind of frustrating trying to figure out what constitutes quality equipment even when you read postings in this forum. My JVC VCR is one of the bold listings on this site of recommended vcrs but elsewhere I'm informed it's an "okay" vcr! I read that the LSI chip is the one to look for in DVD recorders and Panasonic is listed amongst those having it and now I learn it's rubbish!
Good grief!
01-02-2016, 07:21 AM
Remembered
There are different opinions about LSI in Pana DMR models.
I do not know properly.
Here in the German speaking writes a user ...
the ES-15 is the same as the EH65 .... only diskless.
1st place has here the ES-10
Canopus NX 2.Platz
3rd place Pana DMR EH65
Audio should be the ES-10 does not give to feed.
Either in the post by 121 ms delay or see image.
Try what DMR is good ... test is better than studying.
01-02-2016, 08:57 AM
Goldwingfahrer: LSI is the compression chip. He's taking about recording direct to DVD, not using passthrough to PC.
Goldwingfahrer (01-02-2016)
01-03-2016, 03:53 AM
You have to realize that the Panasonic DVD recorders came out 10 years ago. And I'm 10 years older. Lots has happened in that time. I just cannot remember the ins and outs of similar models to the ones I own and use. The ES10 and ES15 were fine. I don't remember the specifics of the ES20 and ES25. Search the forum, as I know it's been discussed in years past. I may have even been the one to discuss it!
When I discuss JVC VCRs, it's usually to discern the finer points of the unit. The buying guide is accurate, and any added comments I make in other threads are just added info to the model. For example, while the 9800 and SR-V10U are both excellent, they differ some. And that's really to be expected, as the units are about 4-5 years apart in age.
The LSI chip is the one to look for, but it's not the *only* aspect to look for. LSI could be implemented differently. While the JVC is best, and the Panasonic is lousy, both are better than a run-of-the-mill Funai or Philips.
It's not just binary: good vs. bad. It's more like a gradient.
