09-17-2018, 01:50 AM
stevevid stevevid is offline
As I inch (mm?) my way forward I run into small things I don't understand. For example the index part of the Select function:
Histogram(Select([<"Histogram", 0, 2, 1>] ,"classic", "levels", "color"))
I know that [<"Histogram, 0, 2, 1>] is the index argument part of the Select function. I don't understand it's structure. I can deduce that 0 is the beginning value, 2 is the ending value, and 1 is the step size. But what in the Select function definition or grammar defines these parts? How does Select know how to use the beginning, end and step size? The Select description just says Index.
Also, I don't understand the use of [ ] and < > and the text string "Histogram". Why is the text string "Histogram" in the Index argument?
I look forward to someone advancing my education.
Steve
Rip DVD audio/edit/return to DVD structure Reading Bug Edit Video, Audio 6 01-30-2016 07:56 PM
VirtualDub and Avisynth filter help? pinheadlarry Restore, Filter, Improve Quality 46 09-17-2014 10:50 PM
Avisynth for improving resolution? merchantord Restore, Filter, Improve Quality 8 11-28-2013 06:24 AM
Make new DVD menu structure that contains another DVD as a subset? Joekster Author, Make Menus, Slideshows, Burn 1 05-25-2011 07:15 PM
