04-07-2021, 09:34 AM
chrisbati chrisbati is offline
Hi,
I'm wondering what's the best wf from capture to final edition ?
As i'm capturing VHS, Video8 or DV, the question is mainly begining or finishing with my editor (adobe premiere pro), so:
1. capture in avi huffyuv
2. QTGMC to deinterlace only, in virtual dub
2b. Which format should I use to export my deinterlaced video ? to go to
3. Adobe premiere to cut and post treatment
4. Final export in adobe (but not too happy with the way adobe decoder works) or back to virtualdub for final encoding (and which format to use) ?
The other possibility is to swap Adobe and QTGMC so:
2. Adobe premiere to cut and post treatment
2b. Which format should I use to export my video ? to go to
3. QTGMC to deinterlace only, in virtual dub
4. Final export in virtualdub for final encoding (and which format to use) ?
Advice welcome !
Thanks in advance
Chrisbati
Keeping 4:2:2 all the way to final encode? latreche34 Encode, Convert for discs 4 05-28-2020 10:13 PM
Video capture workflow, some final questions? buncho Project Planning, Workflows 12 01-24-2019 04:56 PM
Convert Hi8 to digital for Final Cut Pro (FCP) editing? gb27 Capture, Record, Transfer 10 12-18-2014 07:53 PM
Transfer vs. Capture with Canopus ADVC 110 - Final Cut is re-encoding? Johntomk Capture, Record, Transfer 2 11-17-2013 09:12 PM
From Sony MiniDV to final DVD ravid57 Capture, Record, Transfer 29 10-01-2004 11:15 AM
