A few questions for you if you don't mind. From reading in the forums your knowledge is better than everyone else.
What is the best way to create SVHS to DVD? Picture quality is the most important.
Here are my thoughts…..
I just tried a capture card and it took way too long to record and than burn. The quality is not even close to SVHS direct to the DVD recorder.
The plus using the PC is that you can restore the sound and change some of the picture settings Brightness/Contrast ect. Plus you can edit up the video….The - is the time it takes and the picture looks computerized
My goal is to create the DVD and not have to go back and re do it.
My thinking is this:
I need like a sound amp to play with the sound out of the SVHS player which than gets sent to the DVD recorder. Any advise?
Is there a device on the market that lets you edit the picture before it gets to the DVD recorder..Brightness/Cropping and things like that….
What are the better DVD recorders on the Market?
What is the best way to get a good picture that looks maybe better than the actual playing from an SVHS player?
This is a workflow topic.
The key to any good workflow is maintaining quality from the earliest video sources all the way to the final output. This includes the VCR, capturing hardware/software, editing and restoration, compression/filetype formatting, encoding specs, authoring, and final preview/playback.
The best way to convert S-VHS to DVD is to start with an excellent tape signal, using a high-end S-VHS VCR and an external TBC. That will stabilize and clean up the signal. Audio processing hardware is suggested next, for pre-restoring audio.
You can pre-adjust the image quality using a proc amp, to alter color, contrast, brightness, etc. These are as low as $50 for mediocre 1980s units on eBay, all the way up to modern broadcast-quality proc amps from SignVideo or the now-gone Elite Video. The SignVideo units is about $450 new:
http://www.signvideo.com/single_dual...-processor.htm -- just as an example.
Capture to a good DVD recorder or capture card.
Your quality issues -- "the quality is not even close to SVHS direct to the DVD recorder" -- are likely related entirely to the hardware and/or software used for capture. This is a common problem, not all devices are made them same. I'd go so far as to suggest most are really crappy, especially items sold in consumer stores like Best Buy (electronics), Walmart (general retail), or Office Depot (office supply).
If your video looks fine as-is on capturing input, then you can choose to skip advanced restoring (and associated uncompressed/lossless capture) choosing to go direct to DVD-Video MPEG files.
If your edit needs are basic (removing commercials / cutting unwanted scenes), you can use a good MPEG editor like Womble.
More Womble help/information at:
NOTE: I need to update the links on where to buy Womble -- they changed their site a few weeks back, it seems, and failed to provide redirects on their own server -- bad website management.
If you need more complex editing, however, we're back to uncompressed or lossless capture, for best quality.
Hope that intro helps some...
Workflow advice gets pretty in-depth and lengthy. For the most detailed answered,
upgrading to Premium Member status ($20 option) is highly suggested. You'll need to
register for the forum first, if you've not done so already. It's less than the price of a book, but you'll likely find it far more useful!
And the first thing I'll need to know, to get you the custom one-on-one advice that helps your specific need, is a budget. What's the $$$ you're able to spend on this? That's what I'll need to assemble a list of items. There's no point in suggesting items that cannot be afforded -- I try to avoid generic advice, that doesn't help you.
Thanks.
| This question was asked in a private message. Rather than hide our tech advice in private conversations, Site Staff will often answer PMs (from any site) here in the digitalFAQ.com forum, so that others may read and benefit from our expertise. Please continue the conversation here. Either login or join as a Free Member, and we can continue troubleshooting your video, photo or web related issue. Thanks for understanding our tech Q&A policies. |
