If a user does not have the font that you are using on your website on their machine under "Fonts" then it will be displayed via the default of the system rather than what you use.
The best way is to get the viewers to install the font that you are using on their machines, Windows is quite good for this but normally most websites are done in the standards "Tahoma, Verdana, Arial" which is very standard in most computer systems.
If you use a font that is not on a users computer, they will need to install it.
