03-08-2024, 09:07 AM
Persimmonrat Persimmonrat is offline
I'm looking to build a capture pc using an agp ati capture card. The problem I am facing is that I bought a motherboard that is ide only, and want to know how to best go about using it for my vhs digitization without dropping frames. I have two sata hdds and plan on using a startech adapter on each one to make them compatible with ide. Is this the right plan or should I get a pci sata adapter card for the hdds to run off of. Is it also wise to use the pci to sata to connect to an esata card for external transfer? Any help is greatly appreciated.
Below is the hardware I have.
Mobo: ECS P4M800Pro-M Socket 775
IDE to SATA Converter:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Pcie to sata card:
03-08-2024, 10:56 AM
7jlong 7jlong is offline
Hmm. The spec sheets for both v1.0 and v2.0 of that board list (2) SATA ports? Looking at the pic of this board that's still up at the 'Egg, there's two SATA ports right beneath the system battery?
I'd either look closer at your board, or the board's model number. Something isn't right here.
03-08-2024, 10:59 AM
Damn, I completely missed those 2 ports. I need 3, so what would you suggest? Put the OS hdd on ide or use a pci sata card for e sata?
03-08-2024, 11:05 AM
I have a very similar late-model AGP w/SATA board and went with IDE for the system/software (C:\) drive. It only holds Windows, VirtualDub, WinDV and the Turtle Beach control panel, so IDE is plenty speedy and old BIOSs always seemed to play nicer with OS on IDE anyway. All captures go to SATA.
03-08-2024, 11:30 AM
mrmuy97 mrmuy97 is offline
Except that:
The specs state 2x SATA ports, the pics show SATA data and power cabling, plus I can see them in the pictures, directly underneath the CMOS battery, which is directly underneath the IDE ports on that MB.
... plan on using a startech adapter on each one to make them compatible with ide. Is this the right plan or should I get a pci sata adapter card for the hdds to run off of.
Per the above, shouldn't need to do either.
... and want to know how to best go about using it for my vhs digitization without dropping frames. I have two sata hdds ...
You're on the correct path. I'd prefer an Intel chipset over VIA, but you're most likely fine unless anyone knows of issues it has with the specific ATI capture workflow you'll be doing. Personally I use large SATA SSDs for the OS and initial captures, then copy to HDDs for archiving. But if you only have the 2x HDDs, that's fine.
... Is it also wise to use the pci to sata to connect to an esata card for external transfer? Any help is greatly appreciated.
Personally I prefer to power off the computer and swap drives when necessary (not very often, not a big deal). Stay as simple and direct as possible, whenever possible. E.g. using SATA ports direct on the MB 1st choice, PCI(e) card for SATA or NVMe 2nd choice. So 2x HDDs on MB SATA ports, check, easy.
What exactly are the HDDs? All bare, normal, internal SATA drives?
proper vcr+line tbc ---(Y/C)--> proper frame tbc or "tbc-ish" ---(Y/C)--> capture
Capture workflow feedback? (SATA II, AGP) mrfrankmrfrank Project Planning, Workflows 4 02-01-2022 12:05 PM
ATI All In Wonder video capture card, with capture computer, for sale [SOLD] kpmedia Marketplace 1 05-23-2011 02:09 PM
Firewire to SATA/IDE kits? & USB to SATA/IDE kits for overnight backups Sossity Computers 7 04-12-2011 03:17 AM
